Activity Forums Compression Techniques quicktime to idvd
  • quicktime to idvd
    Posted by John Napier on April 6, 2008 at 11:02 pm
    Hi Guys,
    I would be greatful if you could help me out:
    Because of the chapter issue with imovie7 i have to export my movie to Metadata Hootenanny to insert chapters, (no problem) but What i would like to know is what are the best settings in quicktime for exporting data which lasts 1hour and 27 minutes, quality is very important as its a friends wedding dvd.
    Thank you for time guys.
    J.
    Daniel Low replied 18 years, 5 months ago 2 Members · 5 Replies
  • Daniel Low
    April 7, 2008 at 8:55 am
    What was it shot on? DV?
    If so, export it as that, if not, export it at whatever the source is/was, no point in adding an additional transcode step.
    Did I understand your question correctly?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • John Napier
    April 7, 2008 at 9:15 am
    Thanks for your help daniel
  • John Napier
    April 19, 2008 at 8:34 pm
    DV quality is fine, however, the size is 17GB, is there any way of compressing it down in quicktime but still retaining the high quality?
    j
  • John Napier
    April 21, 2008 at 1:46 pm
    j
  • Daniel Low
    April 21, 2008 at 1:56 pm
    You could try the MotionJPEG B codec. If your source is progressive use the PhotoJPEG codec.
