Activity Forums Apple Final Cut Pro Legacy Quicktime to AVI
  • Quicktime to AVI
    Posted by Niti Shah on December 6, 2007 at 6:17 am
    Hello
    We are facing one problem, when we export the file from fcp or quicktime to quick time in avi format it get exported till 18 minute duration. It doesn’t export more then 18 minute if we try to do more then 18 min it gets exported only for 40 to 50 seconds or so and file size show 4 to 5 GB. What could be the reason? Kindly advice on this.
    We have to do this because we are using FCP as a NLE and our Playout system excepts only AVI with DV compression.
    Regards
    nikie
    Savio Iyer replied 18 years, 9 months ago 2 Members · 1 Reply
  • Savio Iyer
    December 6, 2007 at 9:08 am
    You should try converting it using Compressor. Export your project to quictime movie and import it into compressor and use the avi preset to convert it.
