Activity Forums Compression Techniques quicktime to avi mpeg streamclip delivers black screen – what gives?
  • quicktime to avi mpeg streamclip delivers black screen – what gives?
    Posted by Angela Anderson on May 27, 2010 at 4:11 pm
    i just tried to convert a quicktime (768 x 576, 25fps, h.264, no audio) to an avi file using mpeg streamclip for playback on a windows machine. i used the exact same settings (including h.264 codec) for the avi export, and what i got was a slightly bigger file with a black screen ()in quicktime, it was white in mpeg streamclip). can anyone tell me why this is happening and what would be the best bet for encoding a .mov to .avi with the likely chance that it would play on a windows machine?
    This was done in a pinch for a friend for her exhibition (like, an hour before) and know nothing about this windows machine and it’s playback capabilities, let’s assume default windows…
    i did this on my old macbook (2.0 ghz, 1g ram), i have mpeg streamclip 1.9.2 and perian, which might be outdated…can’t figure out how to see what version it is.
    thanks for any advice!
    Andy Thibeault replied 14 years, 9 months ago 6 Members · 8 Replies
  • 8 Replies
  • Daniel Low
    May 27, 2010 at 4:38 pm
    H.264 does not mix well with avi.
    Sent from my iPad Nano.
  • Craig Seeman
    May 27, 2010 at 4:57 pm
    See this post
    https://forums.creativecow.net/readpost/20/865446
    or read through the thread.
    If you read the threads I was quoting from it does mention that apparently some people are using H.264 AVI and it can be played back but I believe one must have plugin/player that can do this, installed (although the exact thing escapes me now).
  • Angela Anderson
    May 28, 2010 at 8:57 am
    thanks, i did read through that thread but it didn’t really answer my question. I’d like to know what codec to use to create an avi that could be played by most windows machines. I actually realized that this file was going to be played on a lcd monitor and then i really started to wonder what codec would be used. any suggestions? and then what program to use – mpeg streamclip? thanks!
  • Craig Seeman
    May 28, 2010 at 6:03 pm
    Why not keep it simple and use WMV9.
  • Chris Blair
    May 29, 2010 at 2:51 pm
    The end user with the Windows machine would likely need FFMPEG and FFDSHOW installed in order to play the resulting file. They’re both free, open-source utilties that add all kinds of codecs and direct show filters so that Windows systems can playback just about any codec out there. But…they can be very confusing to setup and can mess up or change how various media players function.
    There’s also a direct show plugin that would allow a Windows system to play any Quicktime or H.264/mp4 file directly in Windows Media Player, KMPlayer, BSPlayer and a few other Windows based media players. It’s also free and can be found here:
    https://www.medialooks.com/products/plugins/quicktime_plugin.html
    So if the Windows machine has this plugin, it can play just about anything that a Quicktime based application can output.
    One question, can Quicktime play the resulting AVI file you’re creating? If it can’t, it might not be a codec or direct show filter problem but something messed up in the encode.
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
    Read our blog http://www.videomi.com/blog
  • Angela Anderson
    June 1, 2010 at 1:19 pm
    Thanks for the advice, especially the links to the plug-ins. Quicktime (on my mac) plays back the avi file, but what it plays back is a black screen, if that makes sense. There definitely seems to be an encoding issue with mpeg streamclip. But now my question is, if I have to convert from quicktime to avi on my mac, what codec is the best to use? I’m especially thinking about if it’s not possible to install codecs on the window’s machine (i.e. really last minute…)
    thanks!
  • Nadia Hausfather
    June 5, 2011 at 1:55 am
    I am having the exact same problem and would love similar advice!
  • Andy Thibeault
    November 15, 2011 at 4:55 pm
    Same here, would love to get an AVI without the Divx watermark on the bottom.
    star wipe
