Activity Forums VEGAS Pro Quicktime Templates?
  • Quicktime Templates?
    Posted by Rich Stahle on July 25, 2005 at 6:18 pm
    Is there someplace w/more templates for Quicktime as configured via Vegas?
    I’m looking for – say – a 384K option, something in between 256 and 512. I don’t get how the bit-rate value translates here . . . I must be having a bad day or something *LOL*
    Underground Music Television
    Seth Bloombaum replied 21 years, 1 month ago 2 Members · 1 Reply
  • Seth Bloombaum
    July 25, 2005 at 7:36 pm
    You can make your own.
    From the Render As dialog, click on custom, set the parameters you want, then name the template in the top-most field, add comments if you want, and click on the disk icon to save. You’ll have your new template forever.
    384K refers to 384Kb/s, or, 384 kilobits per second, commonly referred to as bitrate. Note that this is bits, not bytes. Likewise, someone with a 56K modem might actually connect at 48K, and if you look at the template settings for 56K you’ll see a video bitrate of about 38K and an audio bitrate of maybe 8K. A DSL connection might be anywhere from 512K to 1.5M, etc.
