Activity Forums Avid Media Composer Quicktime Reference Wrong Frame rate
  • Quicktime Reference Wrong Frame rate
    Posted by Joe Kaczorowski on May 4, 2008 at 3:40 am
    I am trying to export Avid Media Composer Sequences to a quicktime reference file, and import that into Adobe Encore to make a DVD. When i try and import as assets into Encore it says it must be 24 or 29.97 frames per second. I checked the movie info and the fps is different for each file. like 29.74 and stuff around there, but all different and seemingly random. Any help?
    -Joe
    Joe Kaczorowski replied 18 years, 4 months ago 3 Members · 4 Replies
  • Grinner Hester
    May 4, 2008 at 8:58 pm
    Hi Joe.
    If you select same as source for your reference settings, ya otta be all rockin like dokken.
  • Joe Kaczorowski
    May 5, 2008 at 3:19 am
    no luck… when i tried to do that (first of all there was no same as source in the quicktime ref dialog. it did say use dv codec. Since dv is my source i selected that, and it still gave me a weird random frame rate.
    i tried to take screen grabs but have been unsuccessful at posting them in here.
  • David Braswell
    May 5, 2008 at 12:52 pm
    Joe, you need to duplicate your final sequence an mixdown all video tracks to one solid video track with NO black (filler) before you export your sequence. It’s a petty annoyance to us Encore users, but try to reference black and you’ll get goofball frame rated.
  • Joe Kaczorowski
    May 7, 2008 at 6:43 am
    Video Mixdowns worked. Is this a problem with sync? since i am not set up with a sync generator avid doesn’t know what exact frame rate to make black? I am going to try this at work with my machines that are hooked up to sync gen and see what happens because i’m curious. Thanks for all the help. Now i am in the authoring forum asking questions about a whole new slu of problems.
    -Joe
