Activity › Forums › Avid Media Composer › Quicktime Reference problem in Sorenson 5
  • Quicktime Reference problem in Sorenson 5
    Posted by Craig Toussant on September 8, 2008 at 2:22 pm
    Hey all,
    I’m exporting a Quicktime Reference from Avid MC using the “send to sorenson for dvd encode” and bringing it into Sorenson Squeeze 5.0.1.1. I get an error message saying Sorenson does not support my file type. In the past I’ve had no problems getting an mpg2 conversion from a quicktime reference using sorenson. My alternative is to make a quicktime mov that sorenson is accepting but my project is 45 minutes long and Avid won’t let me export something that large as a .mov. In the quicktime settings in the control panel I checked the box for safe mode. I’ve tried multiple qt ref settings within avid and still get the same message. The media is locally on the same pc so it’s not a problem with referencing it. I don’t know what else to try, I’m at a loss.
    thanks,
    Craig
    David Seader replied 18 years ago 5 Members · 9 Replies
  • 9 Replies
  • Michael Phillips
    September 8, 2008 at 9:28 pm
    Make sure “Safe mode” is active in the QuickTime preferences/Advanced tab.
    Can you see your program when launching in MoviePlayer?
    Michael
    Michael Phillips
  • Jon Zanone
    September 9, 2008 at 11:37 am
    You could also try to export your Quicktime reference, then start Sorenson and encode as normal. In other words, don’t have Avid start up Sorenson.
    Jon
    “Jamming our heads full of figures and angles
    And telling us stuff that we already know”
    Willie The Wandering Gypsy & Me
    Billy Joe Shaver
  • Craig Toussant
    September 9, 2008 at 1:58 pm
    I do have safe mode enabled. And actually I can’t open my quicktime reference file in the movie player. Is there a quicktime component I need to download or is there something that came with sorenson that I didn’t install?
  • Michael Hancock
    September 9, 2008 at 5:14 pm
    What version of Quicktime do you have installed? I don’t think Sorenson like the latest version (7.5).
    Otherwise, have you tried reinstalling Sorenson to see what happens? Maybe something was corrupted during the install. I’ve never heard of this issue.
    Sorry I can’t help more. I’d just check my quicktime version. If you have 7.5, try rolling back to 7.4.
    Michael.
  • Craig Toussant
    September 11, 2008 at 5:16 pm
    Thanks so much for answering.
    I got on the phone with sorenson and then avid. My quicktime player wouldn’t play my reference files which led to a quicktime/avid problem. When talking to avid I found out that I have too new a version of quicktime. I got a hold of the older version that my avid is meant for and bam! the quicktime player works and it works in sorenson. Apparently Avid is very specific on it’s quicktime.
  • Michael Hancock
    September 11, 2008 at 5:48 pm
    [Craig Toussant] “Apparently Avid is very specific on it’s quicktime.”
    Truer words have never been said. Here’s a matrix for future reference–it tells you the OS, Quicktime and nVidia drivers that work with your version of Avid Media Composer:
    Media Composer Matrix
    Michael.
  • David Seader
    September 22, 2008 at 9:22 am
    I am having a similar problem. Did you have to reinstall Sorenson or Avid after you installed the earlier version of Quicktime?
  • Michael Hancock
    September 22, 2008 at 12:06 pm
    No. Just uninstall Quicktime and reinstall the right version. You shouldn’t need to reinstall Avid or Sorenson.
    Michael.
  • David Seader
    September 22, 2008 at 8:36 pm
    Thanks, it finally worked after I uninstalled the latest version of iTunes. Even though I changed to the earlier quicktime version, it still did not work until I got rid of iTunes.
