Activity Forums Apple Final Cut Pro Legacy quicktime reference movie into compressor – wrong aspect ratio
  • quicktime reference movie into compressor – wrong aspect ratio
    Posted by J clive Jordan on July 5, 2009 at 7:28 pm
    Hi, I’m trying to compress my movie edited in 1080i HDV to the h.264 iPod video 640×480 setting.
    I’ve done this many many times exporting directly from FCP to compressor (please don’t yell at me – I know this is wrong – alright fine yell).. I have read that it is better to:
    1. make a quicktime reference movie
    2. open that in compressor
    3. render (compress) into the correct format
    When I do that it messes with the aspect ratio (making it even wider) any suggestions?
    J
    j clive jordan
    http://www.kitesites.com
    check out the latest episode!
    Michael Sacci replied 16 years, 11 months ago 2 Members · 1 Reply
  • Michael Sacci
    July 5, 2009 at 9:32 pm
    Your video needs to be 640×360 (not 480) to keep the 16:9 aspect ratio. Go to the Geometry Button and set the Dimensions (encoded pixels) to 640×360 and you should be good to go.
    There is nothing wrong with Export?Using Compressor from FCP, it takes longer and ties up FCP but it gives you the best results, so if you have the time go right ahead on do it.
