Activity Forums Avid Media Composer Quicktime Reference – all media transcoded but still getting “no can do, AMA linked” error!
  • Quicktime Reference – all media transcoded but still getting “no can do, AMA linked” error!
    Posted by John Kim on July 12, 2011 at 7:51 pm
    I have a very simple sequence of about a dozen clips. The sequence is a minute and a half long.
    The clips originated as CANON MXF files shot on a Canon XF100 camera. I used AMA to link the clips and make selects in a sequence, and then I transcoded this sequence. For good measure, I double checked by looking at Media Relatives for this sequence. I checked every clip to make sure that it was pointing to the DNxHD 115 transcoded media on my drive. No problem.
    Still, when I try to export a Quicktime Reference movie an error is returned notifying me that the export could not be completed because there is AMA-linked media.
    This is clearly a bug. Is there a workaround?
    Terence Curren replied 15 years, 2 months ago 2 Members · 1 Reply
  • Terence Curren
    July 13, 2011 at 5:22 pm
    You could try copying the timeline to your source monitor, then create a new sequence and paste them into it. Just in case there is some metadata weirdness in the sequence.
    To tell if the clips are the issue, try exporting a reference movie of one of the clips.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
