Activity Forums Apple Final Cut Pro Legacy quicktime pro with fcp 4.5
  • quicktime pro with fcp 4.5
    Posted by Arty Gold on September 30, 2005 at 6:38 pm
    hi guys…
    hey just got a new g-5 2.7 dual…
    and i’m transferring everything over…
    now final cut is installed and i’m prepared for some glitches…
    however when i go to load quicktime pro’s info it tells me that the registration number is invalid…
    so then i’m thinking that’s because it comes with qtp 7….but when i go to the download page to switch it back to 6.5ish….it says it will only work on os x.3 is that right?
    what’s the solution ?
    thanks alot
    Arty Gold replied 20 years, 11 months ago 2 Members · 2 Replies
  • Joseph Bradley
    September 30, 2005 at 11:45 pm
    QT 7 works for FCP 5 and OS 10.4. So you have to use an older version.
  • Arty Gold
    October 1, 2005 at 4:22 pm
    sorry…i think i didn’t describe that enough…
    the problem is that i need to reinstall 6.52 quick time pro so i can use my codes….
    but the reinstaller i found on apple doesn’t work on tiger….
    is there one and if not what do i do ?
