Activity › Forums › Maxon Cinema 4D › Quicktime output in R11
  • Quicktime output in R11
    Posted by Simon Hutchinson on October 15, 2008 at 2:20 pm
    I have just upgraded to R11 and there is no longer the option to export an animation as a quicktime movie.
    I have quicktime installed and am running a 3DBOXX.
    Am I being blind here, or is there some sort of activation I need to go through?
    Thanks in advance.
    Jethro
    Laura Marjuki replied 17 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Nolan Scott
    October 15, 2008 at 7:38 pm
    Render Settings…
    Output / Presets (tick the little triangle)… from the drop-down make your choice…
    Save / Format / drop-down – QuickTime Movie / Options…
    Cheers
    Nolan
  • Simon Hutchinson
    October 16, 2008 at 9:38 am
    The problem is under the format options quicktime is not displayed. The only video option is avi movie.
    Is there something else i need to do from a codec point of view to make quicktime appear as an option?
  • Nolan Scott
    October 16, 2008 at 10:34 am
    Using Cinema 4D R 11.012 / QuickTime 7.5.5 / OSX 10.4.11
    Well, I have amongst others, QuickTime Movie, QuickTime VR, but not AVI…
    I guess you’re are using “Windows” … – but that shouldn’t make any difference…
    As far as I know, all codecs that are installed on your system are supported by Cinema 4D.
    (to use QuickTime under Windows, make sure that you have the newest version installed)
    Cheers
    Nolan
  • Simon Hutchinson
    October 16, 2008 at 12:51 pm
    Still no joy. Could it be that c4d was installed before quicktime?
    or is there some way to ask c4d to look for new codecs?
  • Nolan Scott
    October 16, 2008 at 8:48 pm
    Well, I guess Cinema is looking for any codecs at startup… ?
    Can you access the codecs directly with QuickTime…?
    (File / Export / Movie to QuickTime Movie / Options)
    Check your “QuickTime Folder” all components should be in there…
    And check the Preferences in Cinema 4D / Common / Use QuickTime…
    (should have been checked by default…?!?)
    Cheers
    Nolan
  • Simon Hutchinson
    October 23, 2008 at 12:25 pm
    The problem was attributed to the order within which the two programs (quicktime and cinema 4d) were installed.
    If you have this issue simply uninstall cinema 4d and then re-install.
    It will magically make quicktime options appear again.
    It may only be an issue to those running x64, like myself.
  • Esky Ching
    November 7, 2008 at 5:51 pm
    This is the case when you are running 64bit version.
    Simply change to 32bit version and Quicktime will be available.
  • Laura Marjuki
    November 23, 2008 at 1:30 am
    Hi, I was having the same problem not being able to export to quicktime. How do I change to a 32bit version?
    Please explain clearly as I am new to the program.
