Activity › Forums › Adobe Premiere Pro › Quicktime Only 8 bit in CC? Is PPro is unsuable for professional finishing and online?
Posted by Marcus Smith on October 10, 2013 at 12:08 pmHey guys,
Premiere Pro CC is rendering all flavours of quicktime in what looks like 8 bit with Max Bit Depth and Render quality turned on. It doesn’t matter whether you are rendering from the timeline or to a file without previews, with the max bit depth set correctly or not. I’ve tested this now on three independent OSX systems running various to the latest drivers and BM Decklink hardware. With or without GPU acceleration it doesn’t matter.
A quick way to check is to make a HD sequence with pro res 422 HQ at its core, add the four color gradient over a black slug, add a dissolve from black, render and watch the banding!
Basically when un-rendered PPro CC displays 10bit with the gradient colours dithered, but once rendered the colour depth is truncated.
Infact the only setting I could find in PPro that doesn’t band from the timeline is DNXHD440, which is the slowest codec I’ve ever seen rendered.
Anyone else had this issue? Is anyone using PPro for professional online and finishing or only for offline?
Marcus.
Chris Gunningham replied 10 years, 11 months ago 8 Members · 22 Replies -
Kevin Monahan
October 10, 2013 at 3:59 pmHi Marcus,
Have you set up your preview files to be in a 10 bit codec with Maximum Bit Depth checked? See this article: https://blogs.adobe.com/VideoRoad/2011/08/prores-workflow-in-premiere-advanced-options.htmlThanks,
KevinKevin Monahan
Social Support Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Marcus Smith
October 10, 2013 at 9:55 pmHi Kevin,
That blog link is for CS6, and the settings have changed a little since then, but yes, Maximum color depth is selected but makes no difference.
This is true for all flavors of Quicktime.
Are you running OSX PPro CC? I’m wondering if this is only a MAC issue.
Marcus.
Walter Soyka
October 10, 2013 at 10:06 pmI just tried it here.
Premiere Pro CC 7.0.1 running on Mac OS 10.8.4 is correctly output 10-bit ProRes MOV files for me.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Marcus Smith
October 14, 2013 at 8:29 amThanks for checking Walter,
I wonder how are you verifying your output is not truncated to 8 bit? Visually or with an external 10 bit vectorscope? Unless your working in high contrast gradients the difference is almost impossible to see with your eye.
I have created an example project with a gradient and included a Pro Res output render so you can see clearly the banding we are getting.
You can download it here:
https://www.hightail.com/download/OGhlb2VBMm1veE9ybHNUQw
So far the only codec inside PPro CC that does not introduce banding is the DNX440 one. Which is an incredibly slow codec to render, making PPro unrealistic to use as an online tool.
I would really appreciate anyone who has the time to check the project and post your results.
Marcus.
Walter Soyka
October 14, 2013 at 2:40 pm[Marcus Smith] “I wonder how are you verifying your output is not truncated to 8 bit? Visually or with an external 10 bit vectorscope? Unless your working in high contrast gradients the difference is almost impossible to see with your eye. “
Mathematically.
I created a grayscale synthetic test pattern with four bars with the following 10-bit values: 32, 64, 96, 128, and saved it as a 10-bit DPX file. When this file is processed at 10b or higher, these values are preserved. When this file is processed at 8b, instead of the full four bars, we should get two bars due to insufficient precision, with the 8-bit values 0 and 1.
I imported the DPX file into Premiere and output it to ProRes with a variety of settings.
I checked the outputs by loading the files into After Effects, making sure the project was set to 16 bpc, loading each file into the viewer, and cranking the exposure up 16 or 17 stops to count the bars. This can also be confirmed by hovering the mouse over the image and watching the RGB values in the info window.
When Render Maximum Depth is checked, I get four bars in my output files, indicated 10-bit output. When it is not checked, I get two bars in my output files, indicating 8-bit output.
You can download my test project and output here [link].
[Marcus Smith] “So far the only codec inside PPro CC that does not introduce banding is the DNX440 one. Which is an incredibly slow codec to render, making PPro unrealistic to use as an online tool. I would really appreciate anyone who has the time to check the project and post your results.”
DNxHD 440 is an RGB format; the others are chroma-subsampled Y’CbCr. Perhaps your test pattern is showing other flaws unrelated to bit depth.
Walter Soyka
Daniel Frome
October 14, 2013 at 3:05 pmOSX displays ONLY support 8 bit output. That is universal, hard and fast.
If you use a 10 bit video I/O product, the 10 bits are properly displayed on whatever output device it routs to. However, whenever you view something on your OSX monitor it will be 8 bit. That is a limitation of OSX.
I don’t know all the details of your setup, but I know this much is true.
Walter Soyka
October 14, 2013 at 3:21 pm[Daniel Frome] “OSX displays ONLY support 8 bit output. That is universal, hard and fast. If you use a 10 bit video I/O product, the 10 bits are properly displayed on whatever output device it routs to. However, whenever you view something on your OSX monitor it will be 8 bit. That is a limitation of OSX. I don’t know all the details of your setup, but I know this much is true.”
To be totally clear, Daniel is saying that OS X only supports 8-bit display via the GPU.
This does not affect 10-bit monitoring via a video I/O adapter, and this does not affect 10-bit file output.
Walter Soyka
Marcus Smith
October 14, 2013 at 3:38 pmThanks again guys for responding,
Daniel, I’m viewing my output through a Black Magic Decklink via SDI on a Sony BVM HD CRT, so its not that.
Walter I appreciate you sending that file through, the link doesn’t work however.
Marcus.
Walter Soyka
October 14, 2013 at 3:39 pm[Walter Soyka] “DNxHD 440 is an RGB format; the others are chroma-subsampled Y’CbCr. Perhaps your test pattern is showing other flaws unrelated to bit depth.”
For clarity, I think the problem has nothing to do with Premiere Pro CC — it’s that your test pattern is not faithfully reproducible in ProRes 422, or maybe any 10-bit YUVish format. I just tried a one-second dissolve on your 16-bit TIF file on Smoke and it produces the same banded output with ProRes.
Walter Soyka
Walter Soyka
October 14, 2013 at 3:43 pm[Marcus Smith] “Walter I appreciate you sending that file through, the link doesn’t work however. Also did have an opportunity to check to project I sent through?”
Sorry, mate. I edited the post and now the link actually works.
I did test your file, and I see the same thing as you do — but as above, I think that your test pattern will band with ProRes 422 with any system. I tried it on my Smoke system, too, and got the same banded result.
If you try non-synthetic footage, or if you change the design of your test pattern to eliminate the other variables, you’ll see Premiere outputs clean 10-bit ProRes.
Walter Soyka
