Quicktime Not Capturing Correctly On Xena card
I already posted this in the Xena forum:
We are using a Xena LS card in a dual 2.4 Xeon running Windows XP. I wanted to try Quicktime capture in Premiere Pro 2.0 so I installed the trial version with Quicktime 7.
The card is set to capture 720×486 29.97 and it seems ok in PP but Quicktime plays it back as 720×720. Other programs see it that way too.
Any suggestions? I’ve tried reinstalling Quicktime and even running QT 6.4 but same problem. We are using the Quicktime files for another program so they need to be seen as the correct resolution. I don’t have Quicktime Pro installed, but not sure that would help.
Currently, when they are played back in Quicktime the bottom part of the image shows white, where the 486 pixels stop.
