Activity Forums Apple Final Cut Pro Legacy QuickTime necessary data reference error
  • QuickTime necessary data reference error
    Posted by Michael Orlansky on March 4, 2010 at 2:27 pm
    Anyone know what this message means? Is it simply a corrupted file? The file played fine last night when I captured it, today I’m getting this message.
    The movie could not be opened.
    A necessary data reference could not be resolved.
    Thanks.
    Michael Orlansky replied 16 years, 6 months ago 2 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    March 4, 2010 at 6:28 pm
    Is it an export? if so it is referencing media that has been moved or deleted.
    Jeremy
  • Michael Orlansky
    March 4, 2010 at 6:36 pm
    HI Jeremy. No export. This was a straight up capture, 6 clips from a digibeta. 4 of the clips are fine, the other 2 give me that message. Nothing is really different about the clips, they were all capture from the same deck, same computer, in the same hour.
    I’m getting the error message straight from the finder, trying to open the files that way.
    Mike
  • Jeremy Garchow
    March 4, 2010 at 7:36 pm
    [Michael Orlansky] “I’m getting the error message straight from the finder, trying to open the files that way. “
    COmpare the file size of one of the clips that open to one of the clips that don’t.
  • Michael Orlansky
    March 4, 2010 at 7:42 pm
    Files are all around 10 gigs, so it seems like the info is there… This happened once before last week. I have to think its some type of corruption but the files weren’t even touched from the time when they worked to the time we discovered they didn’t.
    Note: these files live on an Xsan. I checked permissions of the files themselves and they are the same as the other ones which played fine.
    Mike
  • Jeremy Garchow
    March 4, 2010 at 10:10 pm
    [Michael Orlansky] “Note: these files live on an Xsan. I checked permissions of the files themselves and they are the same as the other ones which played fine. “
    Yeah, I would assume that’s it’s something on your XSAN. If you copy the file to a local drive, does it work, then?
  • Michael Orlansky
    March 4, 2010 at 10:12 pm
    Nope. I tried that too. The file copies over normally. But once its on the local drive, same result. Error message opening it with quicktime. And when you view it with quick look. The file actually plays down but the video is all black.
    Mike
  • Jeremy Garchow
    March 4, 2010 at 10:30 pm
    That’s very strange. Sounds like it just went kaplooey. If you recapture, does it stick?
  • Michael Orlansky
    March 8, 2010 at 1:54 pm
    Hi Jeremy,
    Thanks for trying to get to the bottom of this, I appreciate it.
    Yes, once I recaptured, the new clips stick.
    Mike
