Activity › Forums › Apple Final Cut Pro Legacy › quicktime movies cloon themselves – help
  • quicktime movies cloon themselves – help
    Posted by Lisskulla on April 23, 2007 at 4:32 pm
    When i export a larger quicktime movie from the timeline (about 1.9Gb), I receive 4 or five more of the same size that are dependent on each other. If I erase any of them, the main file can
    Lisskulla replied 19 years, 5 months ago 2 Members · 2 Replies
  • Bret Williams
    April 23, 2007 at 4:55 pm
    Probably have a PC formatted drive and you’re not exporting at the same format as your timeline. Format it for mac, but not journaled. Use the Disk Utility app in your applications folder.
    If the drive isn’t formatted right, then QT is breaking up the files into 2gig files, with a single reference file that links to those files.
    So you’ve probably got a 1.9 gig DV file, and you’re exporting it as uncompressed, which would make it roughly 5 or 6 times the file size. If you don’t need that (it’s not making the picture any better) then export it qt, and choose current settings, self contained.
  • Lisskulla
    April 25, 2007 at 9:34 pm
    Thanks Bret, that
