Activity Forums Apple Final Cut Pro Legacy Quicktime Movie Output from FCP with Artefacting?
  • Quicktime Movie Output from FCP with Artefacting?
    Posted by Jeremy on October 14, 2005 at 10:31 pm
    Hi all,
    I just shot a commercial with a Panasonic Varicam, downcoverted to MiniDV, digitized to FCP, edited, and now I’m trying to export an uncompressed Quicktime movie. Trouble is, I’m seeing quite a bit of horizontal lines/ artefacting in the image that I’m not really satisfied with.
    Is there a way to avoid this in the export settings, or is this just camera limitations? (I don’t have easy access to an HD deck to review the HD tapes.
    Jeremy
    Jeremy Garchow replied 20 years, 10 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    October 15, 2005 at 11:56 am
    Try exporting a self contained QT movie using “current settings”. You’d gain nada exporting it as anything other than DV anyway.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jeremy Garchow
    October 15, 2005 at 6:13 pm
    Are you watching this movie on your computer monitor? If so, you are seeing the interlace which is present in your DV footage. Watch that movie out to a CRT and the lines will go away.
    Also, listen to Jerry. Keep the movie in dv format. You gain nothing exporting out to uncompressed except time and file size.
