Activity Forums Apple OS X Quicktime Issue
  • Quicktime Issue
    Posted by Josh Wilson on May 13, 2009 at 3:44 pm
    OK, having a weird problem – and I’m not sure how to explain it except for a partly gamma-shifted frame. Here’s a link to to a screenshot: Gamma Shift
    The file is a self-contained export from Avid Xpress 5.8.4.438 running on Windows XP SP2 using Quicktime 7.3. Avid Quicktime codecs are installed. Codec settings for the .mov:
    AVID DV Codec, 720 x 486, Millions
    16-bit Integer (Big Endian), Stereo, 48.000 kHz
    I’m trying to play the file on a Mac, running Leopard 10.5.6 using Quicktime 7.6, and then downgrading to 7.3. No change.
    Has anyone seen this problem before? Any fixes?
    Josh Wilson
    Josh Wilson replied 17 years, 3 months ago 2 Members · 2 Replies
  • Michael Nease
    May 24, 2009 at 5:00 pm
    Does the same issue occur when you play it in XP?
    I would suggest trying to export in a different codec. I’m not sure what codecs you have available on your Avid machine, but I would try exporting a segment in either direct NTSC DV/DVCAM or as an h.264 just to see if the problem is consistent across codecs.
    Michael Nease
    Firebare Productions
    http://www.firebare.com
    Los Angeles, CA
  • Josh Wilson
    May 26, 2009 at 3:41 pm
    Hey Michael, thanks for the response.
    The files play fine on XP and on other OS X machines in our office – Tiger and Leopard. We’ll test some other codecs, but it’s weird that this one machine is having problems. I’ll get back to you.
    Josh Wilson
    Assistant Editor/IT Monkey
    Denver Film and Digital
