Activity Forums VEGAS Pro Quicktime in Vegas?
  • Quicktime in Vegas?
    Posted by Ratray on May 17, 2006 at 3:55 pm
    Hello all,
    I’m a FCP editor and I’m trying to send quicktime files to an audio post house which uses Vegas v.5 on PC to sych with. They say they cannot see the video in my QT’s, although they do get audio? Do I need to output in a certain format/bitrate/framerate/codec? or is there a preference they need to change on their end? I know abolutely nothing about Vegas and/or PC-side video/audio.
    Any ideas?
    Thanks, in advance!
    Donatello replied 20 years, 4 months ago 3 Members · 2 Replies
  • Edward Troxel
    May 17, 2006 at 4:44 pm
    What format did you send them? You might try standard DV (depending on how you are getting it to them).
    Edward Troxel
    JETDV Scripts
  • Donatello
    May 17, 2006 at 4:50 pm
    seems they might need to get a newer version of QT for V5 ..
    make sure they are using QT 6 or 7 .. do not send them h264 files
    .. if they are doing the audio ( pic only for reference) you could send them QT using DV format or a 3mbs stream and change ( custom) the audio to use a no compression codec
