Activity Forums Blackmagic Design QuickTime in Combustion : Corrupt Files
  • QuickTime in Combustion : Corrupt Files
    Posted by Jeff Brown on January 16, 2006 at 8:15 pm
    An issue with QuickTime in Combustion, on the PC side, at least. I think it has been mentioned before:
    Updating to 5.3.1 will cause existing QuickTime (BM codec) files to appear as corrupt in Combustion. Same with 5.2.2. Rolling back to the 5.2.1 driver makes things OK. Other QT codecs seem to read fine.
    Just wondering if there might be a resolution to this soon.
    Jeff
    Jeff Brown replied 20 years, 8 months ago 2 Members · 2 Replies
  • Alan Okey
    January 22, 2006 at 3:24 am
    Combustion 4 on the Mac fixed this issue. Not sure about the Windows version, though. Which version of Combustion are you using on the PC?
  • Jeff Brown
    January 22, 2006 at 3:52 pm
    I’m running 4.0.2 on Win XP Pro. Even tried with the new 5.4 DL drivers and QTime 7. Same problem. I’m trying to get a post through to Autodesk about the issue; it might be more on their side, since the problem only shows up in Combustion.
    -jeff
