Activity Forums Adobe After Effects Quicktime H264 compression mode question
  • Quicktime H264 compression mode question
    Posted by James Harris on July 2, 2017 at 12:17 am
    I have a footage with alot of dark areas and want to use the best compression mode to avoid banding and other compression artifacts.
    I had the same issue 5 years ago and back then I did the editing in AE, then rendered an uncompressed QuickTime footage and did the encoding in “x264” software which was better than “QuicktimePro” in encoding a H264 footages. The result was good.
    This was 5 years ago,today is H264 the best compression type in terms of quality for web usage?
    And has the “quicktimePro” been updated so it does a better H264 compression compared to softwares like “x264”?
    Michael Szalapski replied 9 years, 1 month ago 2 Members · 2 Replies
  • James Harris
    July 9, 2017 at 11:40 pm
    Tried Adobe encoder a few years ago and it gave the same results/quality for H264 as QuickTime pro unless something changed lately.
    Is H264 still on of the best compression mode for the web? Hasn’t anything better been developed in the last years?
  • Michael Szalapski
    July 10, 2017 at 3:30 pm
    H.265 is becoming more supported. Especially good for 4K content.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
