Activity › Forums › Apple Final Cut Pro Legacy › quicktime gurus – graeme – marco?
  • Graeme Nattress
    June 9, 2005 at 12:29 pm
    If the internal SATA won’t play it, I doubt severely a single SCSI will. You need a RAID of somekind. Did you try PhotoJPEG75% codec. It’s excellent and much lower in data rate.
    Graeme
    – http://www.nattress.com – Film Effects for FCP
  • Walter Biscardi
    June 9, 2005 at 1:28 pm
    sorry, totally missed the frame size. not sure what will be good enough to play that back in realtime except a fibrechannel array, but even there, not sure.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Graeme Nattress
    June 9, 2005 at 1:35 pm
    The frame size he’s using is about the same height as PAL DV, but three times as wide, so with a PhotoJPEG codec, any RAID that can play 3 DV streams should handle one stream of this, or for uncompressed, any RAID that would handle three uncompressed streams should be fine, say, 100MB/s, which is certainly doable without going to fibre, which here is giving about 300MB/s playbacks.
    Graeme
  • Paul Nevison
    June 9, 2005 at 2:40 pm
    hey graeme and walter
    thanks for your help on this one – photojpeg seems to be working fine on the small test ive done, the real test will be when i try it on a full length piece – typcially 4-5min. when you say photo jpeg 75 – are you refering to setting the quality slider to 75%?
    I also noticed graeme from your QT demo’s of your excellent plugins that you are an englishman – in the words of Sting – living in New york? LA perhaps.
    system 1 G5DP 2.0 / 2.0G RAM / OS 10.3.8 / QT 6.5.2 / FCP HD 4.5 / CineWave 4.7 / Cinewave RT Pro/ Pro Digital Plus & Pro Analogue BOB
  • Graeme Nattress
    June 9, 2005 at 2:49 pm
    Yes, quality setting at 75%. At that setting it’s a y’CbCr codec, 4:2:2 low compression. At 100% it changes to an RGB 4:4:4 codec with low compression.
    Yes, I’m British, but living in Ottawa, Canada, not in the USA 🙂
    Graeme
  • Paul Nevison
    June 9, 2005 at 3:00 pm
    thanks graeme from one ex-pat to another (im a kiwi living in london),
    i’ve been stewing over this issue for a few weeks – your help has been invaluable!!! also used your standards conversion filter for the first time this week – worked great!
    tally ho!
  • Graeme Nattress
    June 9, 2005 at 3:14 pm
    Thanks. I’m working on an update to the conversion package now. It should be good!!
    Graeme
Page 2 of 2
