Activity Forums Adobe After Effects Quicktime goes white at the end
  • Quicktime goes white at the end
    Posted by Tim Bond on June 2, 2005 at 2:41 pm
    I’ve a 7 second piece that when i render out to QT Animation the last second is a white screen. Works fine if i export to an .avi though. Basically i have a blurred piece of footage with a load of animated text over it. Any thoughts?
    Tim
    Steve Roberts replied 21 years, 3 months ago 5 Members · 5 Replies
  • Tom Brooks
    June 2, 2005 at 6:59 pm
    I’ve seen this, but don’t know why it happens. I’ve worked around by adding black to end of comp, render it out, then lop off the useless white in QuickTime Pro.
  • Jimmy Zito
    June 2, 2005 at 8:01 pm
    Happened to me one time too. Did the same thing with the black at the end. But I’ve rendered out to QT many times since, and it it hasn’t happened again. Weird.
  • Jim Tierney
    June 2, 2005 at 11:00 pm
    This can happen when AE (or more usually a plugin) runs out of memory. The frame fails to render, but AE keeps going and (I think) provides a blank image to QT which renders it as white. Usually this doesn’t continue for long before the render fails. Check the render queue to see if the render finished or not. I’ve seen it occur for about 30-40 frames at the most before it causes a render failure.
    If it continues to happen, break the render up into two sections. Render one out, restart AE, then render the second section out.
    cheers,
    Jim
    Jim Tierney
    Digital Anarchy
    http://www.digitalanarchy.com
    415-586-8434
  • Tim Bond
    June 3, 2005 at 6:24 pm
    Jim,
    thanks – i’ll try that as the render had failed about about two thirds of the way in and maybe buy some more memory.
    Tim
  • Steve Roberts
    June 3, 2005 at 8:09 pm
    If memory is the problem, have you tried purging memory during a render by using the “secret” prefs?
    Search the COW (you might need to search the archives) on “secret” or “schecret”.
    Steve
