Activity Forums Compression Techniques QuickTime gamma drop when transcoding from DNxHD to H.264
  • QuickTime gamma drop when transcoding from DNxHD to H.264
    Posted by Ivan Myles on July 17, 2013 at 5:19 pm
    Has anyone seen a decrease in gamma when transcoding DNxHD/MOV files to H.264 using QuickTime Pro? Images are noticeably darker: grey point in the encoded video is approximately 0.88 of the intermediate files.
    Here are the specifics:
    – DNxHD-90-720-24-10bit/MOV with RGB and 709 color, exported at 48-bit depth setting from Premiere Pro CS6 v6.0.3
    – DNxHD file opened in QuickTime Pro v7.6.9 on Win7-64
    – transcoded to H.264/MP4 at Baseline Profile, 1-Pass and 2-Pass, bitrates from 2500-32768 kbps, key frame distances from 1-24 frames
    – also transcoded to H.264/MOV at auto settings, multi-pass
    – analyzed using RGB Parade and YC Waveform in Premiere Pro
    Ivan Myles replied 13 years, 1 month ago 2 Members · 2 Replies
  • Eric Strand
    July 17, 2013 at 9:52 pm
    What program are you using to transcode? Apple’s Compressor was known to mess with gamma when going to H.264, usually washing the image out a little bit.
  • Ivan Myles
    July 17, 2013 at 10:41 pm
    Thank you for the reply. The files are being transcoded with QuickTime Pro v7.6.9.
    One of the characteristics of the QT/Compressor wash-out issue is an increase in brightness within the shadow regions. In this case the video gets darker after transcoding.
