Activity Forums DVD Authoring Quicktime from DVD
  • Quicktime from DVD
    Posted by Andrew Thompson on February 28, 2013 at 4:49 pm
    Good morning,
    Im trying to make a quicktime from an unprotected DVD using handbrake but am unable to get a clean extraction. Ive tried a few different settings but always end up with what appears to be a problem with the video fields. Here are three screen grabs of a hard cut; The second frame is an amalgamation of fields from the shots on either side of it … This is not how it was recorded on the DVD. Additionally, there are other areas (not on cuts) where the fields appear to be visible.
    Thanks in advance for any help – Hope all is well!
    Andreas Gumm replied 13 years, 6 months ago 2 Members · 1 Reply
  • Andreas Gumm
    February 28, 2013 at 8:19 pm
    Your video seems to be a progressive movie with pulldown applied.
    That means your video is originally 23.976 frames per second.
    So you have to remove pulldown by reverse telecine process to end up with progressive frames.
    Andreas Gumm
    selfemployed media author
