Activity › Forums › Compression Techniques › Quicktime file size?
  • Quicktime file size?
    Posted by Van Kowalski burdge on June 8, 2009 at 8:44 pm
    I have been using Visualhub to do this but I wondered if any other software can do it. mpegstreamclip, compressor and QTpro do not do it…at least I could not find the settings.
    When transcoding to h.264 how can I limit the finished file size to under 500 megs???
    The reason is many of the online video hosting services have a 500meg limit.
    tia,
    Van
    Daniel Low replied 17 years, 3 months ago 3 Members · 2 Replies
  • Craig Seeman
    June 8, 2009 at 8:54 pm
    File size is very much related to data rate.
    Scratches head, isn’t this common sense?
    kbits/second is size when you know the total number of seconds. Of course there’s some variance especially with VBR encode as one may over or under shoot a bit but you can certainly get very close.
  • Daniel Low
    June 9, 2009 at 10:56 am
    Craig is spot on but if you still need the facility I seem to remember that Cleaner from Autodesk can limit to filesize but don’t expect it to get it exactly right down to the last bit.
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
