Activity › Forums › Adobe Premiere Pro › Quicktime file has white grain and noise
  • Quicktime file has white grain and noise
    Posted by Jeremy Wiles on April 26, 2006 at 4:57 pm
    Moo,
    I’ve inserted a quicktime animation file created at 720×540 onto my premier project timeline (Panasonic 24p settings 720×480). Once the file is rendered it plays back with lots of white grain and noise. Does the file first have to be converted to 720×480 for it to work? Should it be 24fps or 29.97?
    Also, when files are rendered out of After effects for placement in a premier project that is set at panasonic 24p settings, do the files have to be rendered at 29.97 or 24p? Someone once told me these were both the same, so I’m a bit confused.
    Jeremy
    Jeremy Wiles replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
