Activity Forums Apple Final Cut Pro Legacy Quicktime exports abnormally large
  • Quicktime exports abnormally large
    Posted by Jburkett on July 1, 2006 at 7:07 pm
    I have exported a few projects to quicktime in the last couple of days. These projects are just under one hour and when they export, the file size is rediculously large. Something like 11 gigs for 50 minutes of video! Other videos I have exported in the past that were longer and exported to be much smaller, say 3 gigs. I think it might have something to do with the fact that we had to trash the plist recently to get playback up again. Where do I go to set the preferences back to compress correctly. I export to DV NTSC. Could there be anything else that I am not doing correctly?
    Jburkett replied 20 years, 2 months ago 2 Members · 4 Replies
  • Ed Dooley
    July 1, 2006 at 8:17 pm
    I guess it depends on what you’re trying to do. DV is 3.6MB per second, so 50 minutes is 3.6×60 (216MB per minute)
    x50 minutes gets you a file size of 10,800MB, or 10.8gigs. Sounds right to me. If you’re trying to compress that even further
    you’ll have to tell us more about what you’re trying to do. Do you want to compress DV even more? Do you want video
    smaller than 720×480? If you export “Using Quicktime Compression” you get settings (under options) to compress DV even more.
    Ed
  • Jburkett
    July 1, 2006 at 8:57 pm
    Ok I understand. So is it safe to assume that the preferences for exporting were altered from the default so they compressed to a much smaller size when i was getting 3 gigs for a video over 1 hour a week ago? So it may also be that the QT movies that I exported a week ago may be lower quailty because they are in fact compressed more than usual. But your reply makes perfect sense, I’m just wondering about those other videos that are over 1 hour but only like 3 gigs in size.
  • Ed Dooley
    July 1, 2006 at 9:12 pm
    When I select DV in Export to Quicktime Conversion, the default is “Medium” for quality. I don’t know how much
    more that default compresses the DV file, but it’s safe to say it’s not as high quality as setting it to “High”,
    which essentially gives you a file that isn’t compressed any more than the DV file was to begin with 5:1.
    If you use Export to Quicktime and select current settings, it should give you a straight DV export (at 3.6MBs).
    I usually go for the “Conversion” settings just so I know exactly what the settings are (you don’t get to see them
    in the regular Export to Quicktime).
    Ed
  • Jburkett
    July 2, 2006 at 2:33 am
    Thank you very much, you’ve been extremely helpful!
