Activity Forums Apple Final Cut Pro Legacy Quicktime export
  • Quicktime export
    Posted by Dan Martland on February 7, 2006 at 11:02 pm
    hi there, really hope someone can help me here as i am pulling my hair out!
    I have finished off my showreel and want to burn it to dvd. Yes i have dvd studio pro but on this occassion i want to use one of the fab templates in idvd. Idvd will only except quicktime files.
    Every time i try and compress my 16:9 movie using either compressor or quicktime, for some reason it always gives me a 4:3 image. Nightmare!
    Im sure im ticking all the appropriate boxes but every time, the same reult!
    The only way i have figured to get the correct aspect ratio is to compress it to mv2 with seperate audio files (which idvd can not handle)
    Hope someone can help!
    Cheers
    Dan
    Dan Martland replied 20 years, 3 months ago 2 Members · 4 Replies
  • Steve Eisen
    February 7, 2006 at 11:24 pm
    Depending on which version of iDVD you have, you can use that template in DVDSP.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Dan Martland
    February 7, 2006 at 11:32 pm
    Just bought the latest version of ilife 06 with the very latest idvd.
    If so how do i use the templetesin dvd studio pro
  • Steve Eisen
    February 8, 2006 at 1:16 am
    I do not have iLife 6 so I can not guarantee this will work. Try this. You can save the iDVD 6 project file (the theme you want to use) anywhere you want on your harddrive and import that into DVDSP as a new project.
    Steve Eisen
    Director-At-Large
  • Dan Martland
    February 8, 2006 at 10:06 am
    No , this doesnt work, it cant handle anything older than idvd 5 or later. Bummer!
    Do you or anyone else happen to have the same problems with the quicktime compressor. All i want is 16:9 movies at its best quality. Maybe im using the wrong settings somewhere, which i dont know about, i have had the same problem in other projects aswell. This restricts me to using only dvdsp.
