Activity › Forums › Apple Final Cut Pro Legacy › Quicktime Export trouble
  • Quicktime Export trouble
    Posted by Peter Berg on September 20, 2010 at 5:32 pm
    Hi all..
    I did a search for this, but didn’t find my same situation.
    I can’t get a Quicktime reference to export. I have a 2 hour sequence and I want to make a DVD. The sequence is 1920×1080, 23.98, uncompressed 10bit 4:2:2. Sequence settings match the footage in it. I have rendered the entire sequence.
    When I try to export the Quicktime movie (current settings, with self-contained un-checked) it says it will be like 4 hours to export. It also seems to get a ‘general error’ after a short while. Just as a test, I then tried to do it with Video only and it was still about 4 hours to export. I thought a quicktime reference would export fast (like less than 10 minutes maybe?). If if says 3 hours to export, I assume it’s not doing a reference right? Seems like it wants to re-compress my sequence for some reason.
    Can anyone help me figure out why it’s not exporting a reference?
    thanks,
    Peter
    Peter Berg replied 16 years ago 3 Members · 5 Replies
  • Jerry Hofmann
    September 20, 2010 at 5:39 pm
    Sounds like the “full” quality effects aren’t rendered… be sure they are too.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Peter Berg
    September 20, 2010 at 6:20 pm
    Hi Jerry…
    good point. But I did make sure when I did my rendering that all the check marks were activated (needs render, rendered proxy, proxy, preview, full, and unlimited).
    So I’m pretty sure I have a fully rendered sequence. No HDV or anything like that going on. Everything is in the Uncompressed 10bit codec. argh… very frustrating.
    -Peter
  • Jerry Hofmann
    September 21, 2010 at 2:10 am
    Were all the render settings set to be of the highest quality? These settings are in the sequence’s settings… maybe some weren’t, so they had to be re-rendered? It’s an odd situation you have there for sure…
    Jerry
  • Ellyne Lonergan
    September 23, 2010 at 11:21 pm
    Hi Peter,
    Did you solve this issue? If so, how?
    Ellyne
  • Peter Berg
    September 24, 2010 at 8:47 am
    I have checked the render settings. The codec is the ‘same as sequence codec’. Under ‘video processing’ it is set to ‘Render 10-bit material in high-precision YUV’. Are those the correct settings to be able to export a QT reference?
    I still could not get the QT reference to work. The solution I used for this export was to try ‘export using compressor’. I used that option and broke up the sequence into a few parts. Using that option, I was able to get compressor to create my MPEG2 files for the DVD. I figured it would be faster that was than doing the long full QT export and then bringing that into compressor to make the MPEG2 files.
    Still really frustrating that I could not get the QT reference to work.
