Activity Forums Apple Final Cut Pro Legacy Quicktime Export Problem – Aspect Issue
  • Quicktime Export Problem – Aspect Issue
    Posted by Kyler Boudreau on April 12, 2010 at 3:32 pm
    Okay, weird situation:
    1) Imported 1442 x 975 quicktime into Final Cut. Setup custom video audio settings to match.
    2) When I export a quicktime from the project sequence it is screwing up the aspect ration. I tell it to use the same settings on export and it does….but the video is squished horizontally with this black edges on the side. So the exported quicktime is technically the right size, but the picture is smashed horiz or stretched vertically. however you say it.
    Is there anyway to make Final Cut leave the aspect alone?
    Thank you!!!!
    _______________________
    kyler boudreau
    http://www.theatereleven.com
    ph.310.425.2231
    Kyler Boudreau replied 16 years, 4 months ago 2 Members · 3 Replies
