Activity Forums Adobe After Effects Quicktime Error movie will not close when rendering in CS5 over network
  • Quicktime Error movie will not close when rendering in CS5 over network
    Posted by Roy Mckenzie on June 8, 2010 at 3:31 pm
    Greetings,
    I have a nagging little issue in After Effects CS5. Quicktime movies that I render are being corrupted (quicktime movie will not close)
    I am working on intel Mac with OS X 10.6 (10A432) and one other workstation with 10.6.3 that is an intel machine.
    I am working (successfully up until now mind you) on a custom built SAN over copper gig. The sever is a mac g5 running 10.5.8
    I updated the server and the issue seemed to disappear, now it is back and it seems to effect movies that are over one minute in length.
    I have combed this forum and the adobe.com forum and I have seen the QT32 server preference issues and alike. None of these problems seem to be what I am experiencing, but I have my suspicions that the QT32 server or permissions may be causing the corruption.
    When I render to network drives I get the corrupted quicktime movie when the render is done on movies that are longer then one minute generally. If I render the same movies to a local drive I have no problem.
    Additionally, if the movie is like 30 seconds or less the problem does not occur on network drives.
    The problem seems to persist with multiple codecs, I am testing still but PNG and Apple Pro Rez are definite culprits.
    I look forward to you help. Thank you
    P.S. Does any one else miss the vector paint plugin?
    Thank you
    Roy
    Roy Mckenzie replied 16 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
