Activity Forums AJA Video Systems Quicktime Error -2048
  • Quicktime Error -2048
    Posted by Chris Kelly on March 6, 2007 at 5:50 pm
    I have been capturing with a KonaLH card on a G5 to DV. I’m using VirtualVTR. Occasionally, a clip will record and play back on a Mac… but not a PC. Most of the clips work, but a select few give me the 2048 error. Anyone had this problem? Better yet, any solutions? I can pull up the offending clips in FCP and edit with them, but not on the PC. Very frustrating. Thanks!
    Chris Kelly replied 19 years, 6 months ago 4 Members · 16 Replies
  • 16 Replies
  • Jeremy Garchow
    March 6, 2007 at 7:23 pm
    The PC probably does not have the codec needed to play back the files.
    Jeremy
  • Chris Kelly
    March 6, 2007 at 8:47 pm
    It’s just Quicktime DV, and it plays files recorded in the same way. It’s just about 1/10th of them give this error while one that was captured on either side of it work fine.
  • Jeremy Garchow
    March 6, 2007 at 9:17 pm
    Why are you using Virtual VTR?
  • Chris Kelly
    March 7, 2007 at 2:17 pm
    Basically, I’m recording our newscasts to DV for our department to make Proof-of-Performance spots. The short of it is every time our master-control-op puts our control room on the on the air, it triggers the VirtualVTR to start recording. FCP is overkill for that purpose, even if it could work. VirtualVTR is the right app for this.
  • Jeremy Garchow
    March 7, 2007 at 3:17 pm
    Cool, that makes sense. i was just curious. I have no experience with VVTR. Have you tried to contact them about it? Does it have anything to do with the file name or structure on the pc side?
  • Chris Kelly
    March 7, 2007 at 3:47 pm
    I’m actually working with them on another issue where one of the two systems we have periodically records at around 20fps. I was thinking maybe someone saw this problem in another application and could at least give me an idea how they fixed it.
  • Jeremy Garchow
    March 7, 2007 at 3:54 pm
    Have you tried using VTR Exchange? I am not sure if it has the automation that you need it to though. It’s a F_R_E_E capture utility for use with a Kona card, and you don’t need FCP.
    https://www.aja.com/ajashare/AJA_VTR_Xchangev3.tar
    Jeremy
  • Chris Kelly
    March 7, 2007 at 4:00 pm
    Haven’t tried it though… it may be worth a look. I think the problem I’m going to run into with it is the RS-422 control.
  • Jeremy Garchow
    March 7, 2007 at 4:16 pm
    …and lack of it you mean? I am not sure if it absolutely NEEDS rs-422 to capture, actually I’m pretty sure it doesn’t. It’s a pretty smart application and can even capture your RP188 tc if your source is HD. You should download it read the release notes and manual. They are both short.
    Jeremy
  • Gary Adcock
    March 7, 2007 at 4:22 pm
    [christopherk] “The short of it is every time our master-control-op puts our control room on the on the air, it triggers the VirtualVTR to start recording. FCP is overkill for that purpose, even if it could work. VirtualVTR is the right app for this.”
    The VTR exchange app from AJA will do this also and its free.
    I love the “grab function” that is great for screen shots or frame grabs….
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
