Activity Forums Panasonic Cameras Quicktime DVC Pro HD codec
  • Shane Ross
    December 21, 2006 at 11:36 pm
    You can only get this codec when you purchase and load Final Cut Pro. It comes as part of the install package.
    Shane
    FCP Preferences set to UNCONTROLLED ADVICE
    Littlefrog Post
    http://www.lfhd.net
  • Shane Dillon
    December 22, 2006 at 4:32 pm
    I found more information. This codec only works with Mac’s, it does not work with PC’s at all. Hense it comes with FCP.
    So if you have a project that you intend to move to another system/platform using a Quicktime Movie, do not use the DVC Pro HD 720P codec unless the system is a Mac. The only way to get the file to work in a PC is to first open it in a Mac and then transcode it to a different codec (None).
    Hope this info helps,
    Shane
