Activity Forums AJA Video Systems Quicktime Downconvertion
  • Quicktime Downconvertion
    Posted by Joel Perez irizarry on January 16, 2007 at 6:58 pm
    I already bothered you with this issue but I still haven’t been able to fix it. I have a 720p 58.97 DVCPRO HD project, and I’m trying to burn a SD version using compressor and DVD studio pro. The DVD looks very soft and the graphics lack quality. I’ve try different techniques, but I still haven’t found a solution. Is there a format I should downconvert to? Does this has anything to do with the frame rate? Which is the best way to do this?
    Shane Ross replied 19 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    January 18, 2007 at 10:20 am
    Don’t downconvert before you burn the DVD. Try first exporting a Quicktime Movie (uncheck SELF CONTAINED and you will export a reference file…much smaller) and then take that into Compressor and choose one of the High Quality DVD encodes, making sure to check the 16:9 letterboxed option. Then burn the DVD. I have had great looking DVDs come out that way. DVCPRO HD footage.
    Shane
    Littlefrog Post
    http://www.lfhd.net
