Activity › Forums › Apple Final Cut Pro Legacy › QuickTime Converted Files Equal To Original MXF Files?
Posted by Mark Fanjoy on October 5, 2008 at 6:17 amJerry, wasn’t sure it was cool with you to ask you an off topic question from our other thread, so I’m posting a new one to solicit anyone else’s opinion as well as yours.
I am importing MXF files into FCP6 which are converted to a new directory into QuickTime files. Would it be fair to say the new QT files are the SAME quality with little or no loss or compression and that these QT files may be used as the final broadcast output files to tape?
Wherever I am…I’m lost!
Jeremy Garchow replied 17 years, 11 months ago 3 Members · 10 Replies -
Andy Mees
October 5, 2008 at 7:04 amabsolutely … unless something weird is going on then the QT is simply a re-wrapped version of the original image data ie the old MXF wrapped is exchanged for a QT wrapper but the content remains the same
Mark Fanjoy
October 5, 2008 at 7:21 amOkay, so there is no need for me to be concerned about the import settings as I do with tape in bringing in the media low, med, high, resolution to manage disk space? The P2/MXF file to QT format is what it is, just a wrapper change?
Jeremy Garchow
October 5, 2008 at 7:49 amI think you were talking to me, Mark, (you said Jerry, I’m Jeremy)
Yes, the footage is the exact same quailty.
If they have version 13 of Media 100, I’d suggest exporting an XML instead of an EDL.
Jeremy
Mark Fanjoy
October 5, 2008 at 7:53 amJerry, Jeremy, Bob, one those!!! 😉
Thank you, guys for your support. I hope I don’t abuse my privilege of asking too many questions, but this forum is OUTSTANDING! It allows me to hurdle the obstacles and continue meeting client deadlines.
BRAVO!
Jeremy Garchow
October 6, 2008 at 3:34 amAbuse of privilege? Never. Please ask away.
I would ask of you for next time to keep related posts in the same thread. It will help future queries that will be searched in this forum. It will also help the fellow moderators to keep your issue together in a concise thread so that we might go back and reread your issue(s).
I know it seems trivial, but we answer a ton of questions and being concise really helps us (i.e. me) keep it all together. 😉
Let me know how your media100 workflow goes. I am curious as to how it handles p2 media and if it operates better with the native MXF structure than FCP and also how the XML interchange is working out with M100.
Thanks, Mark.
Jeremy
Mark Fanjoy
October 6, 2008 at 5:51 amVery cool. Thanks Jeremy for the support. I will update you this week when we go through the transfer from FCP to Media100 process.
Mark Fanjoy
October 10, 2008 at 4:21 amJeremy, I hope you get this message from an old string. Keeping topics in the same thread as you recommended!
You were curious how the FCP to Media100 workflow turns out. It didn’t flow! My editor could not get Media100 to read the original MXF files. Nor could he use the P2CM program to even view the files. He believes it is a compatibility issue with his PowerMac-based system vs an Intel-based Mac system. Bummer.
So, I’m just going to send him the Quicktime converted (wrapped) media files that FCP creates when I Log & Transfer. According to multiple responses here, that media is comparable quality to the original media, so it works out just as well. He can read the QT files I convert just fine.
Jeremy Garchow
October 10, 2008 at 7:38 pm[Mark Fanjoy] “Nor could he use the P2CM program to even view the files. He believes it is a compatibility issue with his PowerMac-based system vs an Intel-based Mac system. Bummer.
“Yeah, could be.
[Mark Fanjoy] “So, I’m just going to send him the Quicktime converted (wrapped) media files that FCP creates when I Log & Transfer. According to multiple responses here, that media is comparable quality to the original media, so it works out just as well. He can read the QT files I convert just fine. “
Cool. It’s not only comparable quality, it is the exact same quality if you are using DVCPro Hd MXF files.
How did the XML interchange work out?
Thanks for the follow up.
Jeremy
Mark Fanjoy
October 10, 2008 at 7:56 pmWe didn’t go there with the XML file. We have maintained a very smooth routine with EDL’s for so long, we’re leaving it at that. I deliver a basic cuts only with occassional split video, or disolves. Nothing fancy. So neither of us understand or appreciate the value of XML files at this time, if there is any at all for us.
Jeremy Garchow
October 10, 2008 at 8:16 pm[Mark Fanjoy] “I deliver a basic cuts only with occassional split video, or disolves. Nothing fancy. So neither of us understand or appreciate the value of XML files at this time, if there is any at all for us.”
I guess that makes sense then if your timelime is truly that simple. An XML would allow for greater flexibility with filters, track numbers, metadata and so forth. It sounds like you don’t need that silly stuff.
I would be curious if you sent an XML to a v13 install of Media 100 if the P2 MXF structure would then remain in tact. That metadata can carry over in an XML but will not carry over in an EDL.
Have fun, Mark!
Jeremy
