Activity › Forums › Apple Final Cut Pro Legacy › Quicktime conversion
  • Quicktime conversion
    Posted by Chris Holland on July 16, 2008 at 3:49 pm
    Hi all,
    I am somewhat baffled at the qt conversion I am getting. Sometimes when I export a movie using qt conversion and using the “broadband high” setting I am getting crappier quality exports than other times and I can’t figure out what i am doing different. The only thing i change is the “broadband high” setting and the dimensions to “880 x480”. Now I know for a fact I used the same export setting on two different sequences but came out with completely different quality. The only thing I could think of was some setting on the sequence/project for output that is rendering it lower quality?
    Any help would be much appreciated 🙂
    Chris
    Chris Holland replied 18 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
