Activity Forums Panasonic Cameras Quicktime conversion issue– export stills
  • Quicktime conversion issue– export stills
    Posted by Rachel Lears on September 10, 2008 at 10:12 pm
    Hello. I’m trying to export some stills from footage I shot on an HVX200A. The footage plays fine in FCP6, but in quicktime it has several large black bars over it. These same black bars appear when I try to export a still through Quicktime Conversion, and show up in the still as well.
    I’m pretty sure this is related to a quicktime codec for Leopard that I installed a few days ago:
    https://www.apple.com/downloads/macosx/video/calibratedqdvcprohddecode.html
    I installed this BEFORE installing FCP on this computer, because I just wanted to be able to see my quicktime movie files in Finder. Before installing they weren’t recognized at all; after installing they appeared with the black bars.
    I installed FCP a few days ago, figuring its codec would overwrite the other. Today, after the still export issue, I erased the Calibrated codec, trashed all FCP and quicktime preferences, but the issue remains. I have Quicktime 7.5.5, FCP 6.0 and OSX 10.5.4. Any thoughts would be appreciated- thanks!
    Rachel
    Rachel Lears replied 18 years ago 2 Members · 2 Replies
  • Greg Booth
    September 10, 2008 at 11:25 pm
    Did you delete the “CalibratedDVHDCodec.component” from the ‘/Library/QuickTime’ directory and the Calibrated directory from the /’Application’ folder?
    Cheers,
    Greg
  • Rachel Lears
    September 11, 2008 at 3:06 pm
    Thanks, Greg! Deleting “CalibratedDVHDCodec.component” from the ‘/Library/QuickTime’ directory did the trick. I had already deleted the Calibrated directory from the Applications, but when I went looking in the Library for Quicktime I went only to the library of my user, forgetting there’s another in the Macintosh HD section. Thanks again!
    R
