Activity Forums Compression Techniques Quicktime / Compressor Frame Size Difference
  • Quicktime / Compressor Frame Size Difference
    Posted by Alex Barreto on January 18, 2012 at 5:28 pm
    I have a long standing issue with SD QuickTime files made in Apple Compressor and I’m wondering if any one has experience with it. When making a SD file in Compressor, I set the frame size to 720×486, NTSC CCIR 601/DV. When the file is then opened in QuickTime, it says the frame size is 640×480. A work around we’ve been using is to go into the Movie Properties and, under the Presentation tab, uncheck the box next to “Conform Aperture to.” This then let’s the movie be 720×486.
    My question: Is there any way in Compressor to make the “Conform Aperture to” box be unchecked every time? It’s a pain to have to uncheck that box for multiple files so we usually don’t make SD files with Compressor. But it would be nice to have that option without the extra steps involved.
    We’re using Compressor version 3.5.
    Alex Barreto
    Vapor Post
    Alex Barreto replied 14 years, 7 months ago 2 Members · 4 Replies
  • Jeff Greenberg
    January 22, 2012 at 6:51 pm
    Duplicate a preset you like and save it with this unchecked.
    Best,
    Jeff G
    Certified Master Trainer | Adobe, Apple, Avid
    You should follow me (filmgeek) on twitter. I promise to be nice.
    My book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Lynda.com – Compressor Essentials 3.5 and 4
    Contact me through my Website
  • Alex Barreto
    January 26, 2012 at 4:44 pm
    Do you mean in Compressor or in QuickTime? I haven’t found this particular setting in Compressor.
    Alex Barreto
    Vapor Post
  • Jeff Greenberg
    January 26, 2012 at 5:00 pm
    I’m totally wrong. I thought you were running into the preserve source aspect ratio setting in compressor (which you could save as a preset and reuse.)
    I’ll take it that you’re downconverting from some HD footage – which probably scales better to 720×480 (than 720×486.) Me, I’d likely have it downscale and preserve the source aspect ratio (in compressor) meaning that I’d do widescreen SD with 6 lines of padding – or at least throw that switch and let compressor work it out.
    I do want to check this – you’re doing a downconversion in compressor to 720×486, but it only shows up in QT as 640×480 (It’s likely that it’s truly 720×480, just displaying square pixels). Compressor may be preserving the source aspect ratio by default.
    I’d test this myself, but I’m crunching for a conference for next week….
  • Alex Barreto
    January 26, 2012 at 9:09 pm
    Actually, in this case, the file is not being down-converted. It starts out as an uncompressed 4×3 720×486 file and is then converted to ProRes. I did try the “preserve aspect ratio” setting under “Output Image Insert (Padding)” but that did not change the result. Neither did changing that setting to “4×3 1.33:1.”
    Alex Barreto
    Vapor Post
