Activity › Forums › Apple Final Cut Pro Legacy › Quicktime compressions for 2hr project to send to composer? Help?
  • Quicktime compressions for 2hr project to send to composer? Help?
    Posted by Sean Fine on September 1, 2006 at 2:06 pm
    Hello,
    I am using FCP 5.0.4. My project is shot and cut on dvcprohd 24p. I am on the East coast and want to send my composer on the west coast a quicktime of the project. I tried compressing the project using H.264 but it was estimated that it would take 27hours. Too long and the composer also said his system cannot handle that codec. I basiclaly need to get my project onto a DVD as data so it has to be about 4g. Does anyone have any suggestions for a widley used codec that could accopmplish this in under 12hours.
    Sean
    Jerry Hofmann replied 20 years, 1 month ago 3 Members · 4 Replies
  • Jerry Hofmann
    September 1, 2006 at 2:43 pm
    What can the composer work with? you’ll most likely need more than one DVD.
    Jerry
  • Sean Fine
    September 1, 2006 at 2:49 pm
    He asked for DVC-PRO 25 DV codec. How would I use two DVD’s
  • David Roth weiss
    September 1, 2006 at 3:23 pm
    Sean,
    Since DV is about 12-13gb per hour it would be pretty hard to send a 2-hour program on two DVDs — that would be more like 6 or 7 DVDs. Your best bet is to export the project to DV and send it to him on a small inexpensive firewire drive that he can send back to you.
    DRW
  • Jerry Hofmann
    September 1, 2006 at 5:39 pm
    Or burn the many DVD’s (more like 10 of them) breaking your sequence down to no more than about 20 minutes of show for each export … That’s all you can fit on one 4.7 gig DVD…
    FW drive solution is a good one!
    Jerry
