Activity Forums Adobe Premiere Pro Quicktime codecs not rendering?
  • Quicktime codecs not rendering?
    Posted by Eric Robinsan on May 27, 2010 at 5:44 am
    I posted in another forum here about using more lossless codecs. Someone suggested using Quicktime PNG or animation. I tested it and they worked okay.
    Now, I am trying to do this again. When I export into media encoder it appears as if it loading and then the whole thing renders in one second. I get the green checkmark as if it renders, but there is no file in that folder or on my computer. I can view Quicktime movies so I am not certain what is going on.
    I am using Vista Ultimate. Anyone have an experience like this?
    Eric Robinsan replied 16 years, 3 months ago 3 Members · 6 Replies
  • Jon Barrie
    May 27, 2010 at 9:06 am
    Are you certain the work area bar is not shorter than the entire edited timeline?
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
    http://www.suiteskills.com
  • Eric Robinsan
    May 27, 2010 at 7:00 pm
    Well I am trying to just render a portion of the timeline, so I am shortening the work area bar. Can that not be done with this?
    Thanks for your reply.
  • Sylvia Porter
    May 29, 2010 at 12:33 pm
    You might try checking which version of Quicktime you have, and see if it corresponds to your version of the Adobe software that you’re using.
    Check the system requirements for your Adobe software.
  • Eric Robinsan
    May 30, 2010 at 2:17 am
    I am using CS4 and I have the latest version of Quicktime 7.6.6
    I dont recall when this latest version came out, but I was using Quicktime before and CS4 and it worked fine.
  • Sylvia Porter
    May 30, 2010 at 3:35 am
    I keep a few different versions of quicktime around just for such situations, so I can uninstall one and reinstall another.
    Currently I have CS5 and 7.6.6, and no problems. I never had CS4. But with CS3 I had to change quicktime versions a couple of times to get them to work well together.
    I’m not saying it is quicktime, but the possibility exists.
    You may have seen this, but if you haven’t it might help.
    https://forums.adobe.com/thread/388635
  • Eric Robinsan
    May 31, 2010 at 3:47 am
    Now I am having issues rendering AVI. I cannot get any AVI to render correctly, uncompressed or otherwise. The files are either really slow with the sound way out of sync or they have that along with discoloration. I will keep trying, but I am quite baffled.
