Activity Forums Apple Final Cut Pro Legacy Quicktime changes the aspect ratio on it’s own
  • Quicktime changes the aspect ratio on it’s own
    Posted by Christy Pessagno on November 10, 2008 at 3:50 pm
    When you are exporting out a Quicktime movie to 720×480 via Quicktime Export, it will change the aspect ratio and size to 640×480. This has been quite a headache trying to get it to export out at 720×480.
    The settings we were using were the NTSC 720×480 4:3 size settings.
    We finally exported out using the ‘custom’ size setting and manually typed in 720×480. This worked great.
    As much as this is a solution for people looking for an answer to getting their movie out at 720×480, it’s also a question as to why quicktime does this.
    I understand that it is probably compromising for the square vs rectangular pixels, but how does this automatic change affect other things, like when we bring the file into dvd studio pro, or want to stream it out to a tv?
    Any explanations would be greatly appreciated.
    Dave Walker replied 16 years, 11 months ago 6 Members · 7 Replies
  • 7 Replies
  • Dennis Leppell
    November 10, 2008 at 6:10 pm
    [Christy Pessagno] “I understand that it is probably compromising for the square vs rectangular pixels, but how does this automatic change affect other things, like when we bring the file into dvd studio pro, or want to stream it out to a tv?”
    This automatic change is because QT Export wants to make it a video to be viewed on your computer. That’s why you need to manually change the settings of the dimensions.
    If you send your 640×480 picture to DVD SP you’re going to need to again customize the picture size, adding another level of rendering to the piece, and resulting the final piece not being as good as it could be.
    To correct the problem, you should export only as a self-contained reference file
    Export >> Quicktime Movie >> Current Settings.
    Be sure that self-contained is checked. This will give you your 720×480, the resultant file will be as good as you can get possibly get out of FCP, and the export itself is very quick.
  • Christy Pessagno
    November 10, 2008 at 8:06 pm
    Thanks Dennis.
    So my original solution of doing a custom size export if you are exporting out of Quicktime rather than FCP will also work for that. I just wanted to make sure there wasn’t an unnecessary step i was taking in trying to keep the aspect ratio at rectangular 4:3.
  • Dennis Leppell
    November 10, 2008 at 8:54 pm
    Just to verify, you were originally exporting from FCP using export ====>Quicktime Conversion? If so, that’s why the frame size is being changed. You want to export=====>quicktime movie, and use current settings. This will keep your aspect ratio at 4:3 with rectangular pixels. From there you can use Compressor or Quicktime to change to 640×480 with square pixels
  • Alan Okey
    November 10, 2008 at 10:08 pm
    Just to add confusion to the mix, Quicktime Player is savvy about certain SD video formats – DV and MPEG-2, for example. Quicktime Player will display a 720×480 DV or MPEG-2 movie as 640×480 on screen when played back. This is merely an aspect ratio correction for playback (i.e. 720×480 nonsquare pixels displayed as 640×480 square pixels), and does not change the actual file. This can be confusing for people who expect to see nonsquare pixel output.
  • John Woods
    November 17, 2008 at 10:02 pm
    I have a similar problem when exporting 720×480 interlaced using Compressor. What Compressor 2 generates, with setting standard NTSC 4:3, is an MPEG2 movie that QuickTime describes as 640×480.
    From some of this thread, I get the idea that this MPEG2 movie is really 720×480, and it is just that QuickTime seems to say otherwise, referring to its own display on the computer screen rather than to the movie file itself. But other parts of the thread lead me to believe that the created movie file really is 640×480, and that I need to use a special setting in Compressor to generate a real 720×480 movie. Can someone clarify this?
    John
    John Woods
    WOODS Productions
    Clifton Park, NY, USA
  • Asimo Honda
    March 28, 2009 at 7:45 pm
    Interesting stuff. However, I feel like my situation is opposite. In FCP I’m looking at NTSC format which should be rectangular pixels. When I open my captured footage in Quicktime, it’s not squished width wise. It’s stretch width wise. Does this make sense? What’s the deal?
  • Dave Walker
    September 4, 2009 at 10:04 pm
    My experience is that it is a new movie that is 640×480. It goes in 720x480DV and comes out 640x480MPEG-2. When you import it into DV Studio Pro, it’s a square pixel movie. In one scenario, I went into QT and manually changed the frame size back to 720×480. Then, I re-saved the movie. DSP didn’t like this file and wouldn’t import it. This is a real fine mess!
