Activity Forums Apple Final Cut Pro Legacy Quicktime Bug?
  • Posted by Phillip Van west on March 13, 2007 at 8:13 pm
    After creating a movie in FCP that’s just over 2 hours (2:01:02), I tried to compress it (for MPEG-2) using Sorenson Squeeze. The resulting file (8.52 GB) kept ending at 56:48.
    When I contacted Sorenson about this, they recreated the problem and tracked it down to a bug in Quicktime (vsn 7.1.3 is what I’m using) that doesn’t seem to let it recognize anything larger than about 4 GB.
    When I tried Compressor instead of Squeeze, the resulting .mpg file was 4.23 GB and its video (ONLY – not the audio) stops at about 1:55 (6 minutes short), so I seem to be able to verify it as a QT problem.
    Anyone else seen this?
    pvw
    Phil Van West
    Terra Nova Productions
    Denver, CO
    Video Production/Post-Production
    G5 DP 2.5GHz / 4.5 GB RAM / OS 10.4.8 / FCP 5.1.2 / QT 7.1.3
    Jeremy Garchow replied 19 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
  • David Bogie
    March 13, 2007 at 8:37 pm
    might try the quicktime forum at apple.com
    https://discussions.apple.com/category.jspa?categoryID=122
    Umm., I just dropped over there. Like the iTunes and iPod forums, it’s turned into a Windows-users bash fest. They just come to complain.
    bogiesan
  • Zeliha Bozkurt
    March 13, 2007 at 8:47 pm
    Hi
    Sorry I dont have a solution to the problem but wanted to say that the same thing happend to me twice but I thought it was something I did wrong.
    I too would like to know if there is a fix for this bug.
    Cheers
    Zee.
  • Mark Maness
    March 13, 2007 at 8:54 pm
    Maybe that is one reason that Quicktime updated to version 7.1.4… And now, 7.1.5…
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Phillip Van west
    March 14, 2007 at 2:31 am
    Apparently there has been a 4GB size limit on MPEG-2 file recognition since the QT MPEG-2 Player component came out.
    …makes absolutely NO sense to me.
    pvw
    Phil Van West
    Denver, CO
  • Jeremy Garchow
    March 14, 2007 at 3:56 am
    [pvanwest] “…makes absolutely NO sense to me”
    Well, if you notice VOB files on DVDs don’t go over 2 GBs, so a file that hits a 4GB limit makes a little sense. It’s a formatting constraint I’m sure.
  • Phillip Van west
    March 14, 2007 at 1:00 pm
    VLC plays these files (>4GB) just fine. Ever seen a 2 hour mpeg under 4 GB? I haven’t – it would look awful after that much compression.
    pvw
    Phil Van West
    Denver, CO
  • Jeremy Garchow
    March 14, 2007 at 1:30 pm
    VLC plays a lot of things that QT doesn’t. If you segment your movie into two parts, you will be fine. Perhaps you should try innobits’ BitVice. They provide great results with smaller file sizes.
