Activity Forums Avid Media Composer Quicktime — Avid Xpress Pro Conflict??
  • Quicktime — Avid Xpress Pro Conflict??
    Posted by Brian Thomas on February 5, 2008 at 3:29 pm
    Avid Xpress Pro w/MOJO v5.21 running on HPxw8200workstation
    I think i upgraded Quicktime which is causing playback overrun issues…what quicktime version should i be using to match the above version
    Brian
    Jon Zanone replied 18 years, 7 months ago 2 Members · 1 Reply
  • Jon Zanone
    February 6, 2008 at 12:19 pm
    Latest QT version supported is 7.2 – I would think if you rolled back to 6.5, you should be fine.
    There should be a readme file in the Avid folder on your hard drive. Check there to make sure.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
