Activity › Forums › Apple Final Cut Pro Legacy › Quicktime A/V controls inconsistent w/ viewing size
  • Quicktime A/V controls inconsistent w/ viewing size
    Posted by Brad Bussé on January 27, 2009 at 11:15 pm
    I exported a .mov with Compressor and had the gamma lowered due to the conversion from Animation’s RGB to H.264’s YUV. Without time to re-compress, I tried to adjust the A/V settings to match what the file should look like and then I saved the Quicktime file. On my Mac, everything is fine, but on a PC, the file appears fine when viewed at it’s full 1080 resolution, but it seems to loose it’s A/V settings changes when viewed at half size. Anyone know more about this?
    Brad Bussé replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
