Activity Forums Adobe After Effects Quicktime audio/video out of sync
  • Quicktime audio/video out of sync
    Posted by Coen Deurloo on August 12, 2008 at 8:08 am
    Hi there,
    I have some problems with the Quicktime output in After Effects, the audio is out of sync by a couple of frames every time, no matter what quicktime format I choose, it even happens with Animation. Uncompressed avi is perfectly synced…My comp just contains a lot of psd’s and wav’s, nothing weird going on with that.
    I’ve already searched around a bit for this but there doesn’t seem to be an answer, but isn’t this a MAJOR problem? What do you guys do to be able to export to quicktime properly?
    Tom Munday replied 16 years, 4 months ago 8 Members · 15 Replies
  • 15 Replies
  • Joey Burnham
    August 12, 2008 at 5:37 pm
    I’ve never heard of that problem, but the workaround is just to lay out your video and audio in your NLE and go from there…
  • Coen Deurloo
    August 14, 2008 at 7:10 am
    Thanks Joey,
    What is an NLE? We need to have a final quicktime for the client…
  • Joey Burnham
    August 14, 2008 at 3:50 pm
    It’s a non-linear editing system. Final Cut Pro, Premiere, Avid, etc…
  • Coen Deurloo
    August 14, 2008 at 6:24 pm
    I have rendered the uncompressed avi ( = perfect sync) in Premiere to Quicktime .mov, same problem…
    A collegue of mine even installed After Effects 7 on his PC, since someone said that should help, unfortunatly it didn’t.
  • Thomas Leong
    August 15, 2008 at 6:03 am
    A shot in the dark –
    Small out-of-sync errors are usually due to the difference between 29.97fps and 30fps rendering, for NTSC. Make sure you render to the same fps (frames per second) rate as your original uncompressed avi.
    Thomas Leong
    from PAL-land
  • Lazlo Hollyfeld
    August 26, 2008 at 10:06 pm
    I am also experiencing the same problem. In both AE and in PPro. Quicktime doesn’t honor the frame rate, and I’m using a targa sequence, so there is no “native” frame rate for a sequence of images. Basically quicktime is about a frame off.
    Did you have any luck solving your problem?
  • Coen Deurloo
    October 9, 2008 at 7:31 am
    No luck whatsoever. This is really annoying.
  • James Barnham
    June 14, 2009 at 11:07 pm
    Hi
    did you ever found a solution to this problem? this is a pain..
    J
  • Coen Deurloo
    June 15, 2009 at 8:20 am
    No, after extensive contact with Adobe support there was no solution. Insane…
  • Tobias Kraze
    August 3, 2009 at 1:09 pm
    Might be a bit old, but better late than never 🙂
    Have you tried decreasing the buffer size in the “audio hardware settings” (edit/preferences/audio hardware/settings)? I have had the same problem until I played around with different values. Basically the latency of the sound card cause problems. This fixed the problem for me ONCE. Now, I have that problem in CS4 again, and setting different buffer sizes doesn’t seem to help anymore.
