Activity Forums Blackmagic Design Quicktime and Premier Pro Problem, help!
  • Quicktime and Premier Pro Problem, help!
    Posted by Imaginate on December 27, 2005 at 10:44 pm
    Hi All,
    When i import an uncompressed (no codec) quicktime .mov file into a decklink project in Ppro i can’t playback the clip, i get a huege distortion and the image goes black and white.
    Anyone got the same problem?
    How can i solve this?
    Thanks!!!
    Dimi.
    Pentti Kakkori replied 20 years, 8 months ago 5 Members · 6 Replies
  • Baz Leffler
    December 27, 2005 at 11:07 pm
    Go to video filters “adjust” and apply a ‘brightness & Contrast’ filter set to zero and see if that fixes it.
  • Mihail Angelov
    December 28, 2005 at 3:09 pm
    Yes I have the same problem, I solved it with prerending the clip with After Effects
  • Imaginate
    December 28, 2005 at 5:11 pm
    that is just the problem, it is a render out of after effects, settungs: quicktime compression = none, upper field first
    Dimi.
  • Norman Lafranchi
    December 29, 2005 at 7:27 pm
    You may have to transcode the file to a Blackmagic format in order for it to work. Could be done in After Effects, Quicktime Pro, or other. Or else, render the file from After Effects in a BM codec.
  • Imaginate
    December 30, 2005 at 2:31 am
    I know that it would work then but i suppose it should work with uncompressed also??? In a few day’s i get a lot of uncompressed files from i client, i would be lost if i have to transcode them all, that would be a da&y extra work just transcodeing it.
    Is this a known limitation or could this be a huge bug?
    Is it possible that someone tests this to check wheather it’s my system only or that everyone has this problem?
    Thanks!!!!
    Dimi.
  • Pentti Kakkori
    December 30, 2005 at 9:17 am
    Blackmagic Quicktimes are uncompressed too. Your client can download free codecs from Blackmagic website. They work without BM card.
    https://www.blackmagic-design.com/support/software/
    For uncompressed work I normally use tga-sequence, it is uncompressed and it plays realtime in Premiere Pro in Blackmagic projects. If you have to make little corrections to your After Effect composition you only have to rerender part of composition not all.
