Quicktime alpha problems
Hello All,
I’m really new to trying to learn after effects so guessing this is a really simple problem.
I’m exporting a quicktime from flash with ‘Alpha-transparent’ selected, then exporting this file again from Premiere as: Quicktime 100% Animation compression millions of colours+, which should have the alpha channel.
Then when i import into AE 6.5 it asks how to interpret the footage, straight or premultiplied, i select straight. But when i drag the footage onto the comp or timeline it has a white BG as it did in the flash movie. Is there something i’m doing wrong or need to do?
Be really grateful for any help, as i thought it would be simple…
steve.
