Activity › Forums › Avid Media Composer › Quicktime 7.5
Quicktime 7.5
Posted by Jeremy Presner on August 15, 2008 at 3:24 pmAnyone tested Media Composer 3.01 with Quicktime 7.5? results?
Jeremy Presner replied 18 years ago 6 Members · 11 Replies -
Joe Womble
August 15, 2008 at 3:39 pm3.0.1 supports Quicktime 7.4.5 at this time. I haven’t tried going beyond that for obvious reasons. I suggest you wait until it’s approved to start using it with 7.5.
Regards,
Joe Womble
Jeremy Presner
August 15, 2008 at 3:47 pmThe dilema is that I have FCP 6.0 on my system as well and cannot work on a project that originated on a 6.03 system because I cannot upgrade to 6.03 until I have installed QT 7.5… This is a sad state of affairs!
Jeremy Presner
http://www.presner.com
Editor Film/TV -
Jeremy Presner
August 15, 2008 at 4:05 pmCan I do it with adding another user in the os accounts section?
Jeremy Presner
Editor Film/TV -
Bob Zelin
August 16, 2008 at 12:12 amJeremy –
this is what you need to do. There is no shortcut (and believe me, if there was one, I would have done it, as I built systems with both FCP and AVID on them all the time).You go to Best Buy, or your local mail order company, and order a nice cheap 160 gig internal SATA drive. You install this in your MAC, and load your MAC OS 10.5.4 on this NEW DRIVE. Then you load up FCP, with the latest Quicktime version (7.5), and you have no problems. If you put Media Composer and Final Cut Pro on the SAME drive you will have NOTHING but problems. A small raw SATA drive is very very very inexpensive (dinner out this weekend), and requires no tools or cables to install it in your MAC Pro. As long as you have your original MAC OS disks, this is very easy to do, and will take you about 5 hours this weekend to accomplish.
Bob Zelin
Jeremy Presner
August 16, 2008 at 12:25 amThanks Bob,
I neglected to mention I’m running off a MacBook Pro not a Mac Pro…
I wish i could jam another internal drive in there!
Jeremy Presner
Editor Film/TV -
Bob Zelin
August 16, 2008 at 2:23 pmthen I have an easy answer for you –
ITS NOT GOING TO WORK.
Bob -
Job Ter burg
August 16, 2008 at 2:28 pmGet an external drive, clone your current hard drive (with Carbon Copy Cloner), partition your MBP’s HD, Carbon Copy the “old” install back to one partition, and do a new install on the other partition.
Keep one partition for Avid with the right OS and QT, keep the other partition for everything else. -
Kevin Downer
August 19, 2008 at 2:12 amYou could also get the person who gave you the original project to export it as XML Vers. 3. You could then import that into your older version and it should translate over fine. That is probably your best bet and you don’t have to mess around.
Why FCP does not do this by default is very annoying.
