Activity Forums Adobe After Effects Quicktime 7.5 and ProRes issues?
  • Quicktime 7.5 and ProRes issues?
    Posted by Navarro Parker on June 10, 2008 at 1:31 pm
    Is anyone else running into this problem? The first few frames of any comp I render using ProRes 422 HQ will have a lighter gamma/brightness before the movie settles on the correct value?
    QT 7.5 & AE 8.0.3 & 10.5.3
    James Jacksons replied 18 years, 3 months ago 2 Members · 1 Reply
  • James Jacksons
    June 20, 2008 at 8:43 pm
    After rendering , open it up in QuickTime and select Show Movie Properties. Highlight the video track then click on the Visual Settings tab. Towards the bottom left you should see Transparency with a drop-down box next to it. Select “Blend” from the menu then move the Transparency Level slider to 100%. Choose Straight Alpha from the same drop-down and close the properties window and finally Save.
