Activity › Forums › Apple Final Cut Pro Legacy › Quicktime 7.1.6 – timecode support
Chris Poisson replied 19 years, 4 months ago 14 Members · 29 Replies
Tom Wolsky
May 2, 2007 at 11:05 amI am not seeing this. How are you getting this strip at the top of the window, and at the top of which window, the viewer or the properties window?
I have the extract function, which will make the TC a separate file (would be nice if there was such a function from the FCP timeline window), but I don’t think that’s what you mean.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Walter Biscardi
May 2, 2007 at 11:19 am[Shane Ross] “Quite useless for those of us who send out this stuff out for Client review.”
You can find a “sweet spot” within FCP for exporting for client review and this should get better with the release of FCP 6. When using SyncVUE to review projects with clients, I always had to export from FCP’s timelines. It worked out fine. Not as much control as Compressor, but it worked fine.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”Read my blog! https://blogs.creativecow.net/WalterBiscardi
Lee Berger
May 2, 2007 at 1:05 pmTom,
Did you select the check box for the Timecode Track in the Visual Setting Tab? -
Jon Smitherton
May 2, 2007 at 2:18 pmWouldn’t it be good if you could assign TC to clips?
imagine outsourced shots/graphics coming back with a timecode reference to be resynced in FCP to…
Tom Wolsky
May 2, 2007 at 2:54 pmI’m not seeing what you’re seeing.
If I select the timecode track in the properties window, there is no tab for Visual Settings.
If I select the video track, there is a tab for Visual Settings, but I see no checkbox for Timecode in there.
All the best,
Tom
Russell Lasson
May 2, 2007 at 4:45 pmYou can extract the timecode from the original clip and add it to another movie using QT pro. That could be pretty helpful.
-Russ
Keyframe
May 2, 2007 at 4:45 pm[jon smitherton] “Wouldn’t it be good if you could assign TC to clips?
imagine outsourced shots/graphics coming back with a timecode reference to be resynced in FCP to…”
See my reply to your duplicate post in the later thread “Quicktime 7.1.6 doesn’t see…”
Steve Grimes
Lee Berger
May 2, 2007 at 4:49 pmHere is a screen grab that I hope will help.
https://www.leebergermedia.com/qt_tc_grab.jpg
You’ll notice that I scaled the space where the TC text is displayed. When I first applied the track, It cut off the bottom of the text. The text updates as you play the movie.
Tom Wolsky
May 2, 2007 at 5:01 pmCould you describe the procedure to do this? I get how to extract it, but I can’t seem to figure how to add it into another QT file.
All the best,
Tom
Tom Wolsky
May 2, 2007 at 5:14 pmIf I select the Video track in properties I see this:
https://fcpbook.com/VideoTrack.jpg
On check box for timecode. Adjusting the track height and width makes no difference. I’ve tried it with various material. DV, DVCPRO HD and HDV.
If I select the Timecode track in properties I see this:
https://fcpbook.com/TCtrack.jpg
There is no visual tab to select.
All the best,
Tom
