Activity Forums Apple OS X Quicktime 7 repeatedly crashing after several reinstalls
  • Quicktime 7 repeatedly crashing after several reinstalls
    Posted by Ben Mills on March 13, 2012 at 11:32 am
    I am having some serious issues with QT 7. It was originally working, then I added a number of new codecs/plugins to the Library/Quicktime directory. These were taken from a friends mac whose QT7 was working fine. Then quicktime began not to work even after repairing disk permissions.
    I decided to totally remove QT 7 using AppCleaner, as well as removing any of the new codecs from the library, then repaired disk permissions again and reinstalled QT7.
    Now everytime I run QT7 it crashes after a second or so.
    I am fairly mac savvy and am capable of using terminal if needs be.
    Please see below the crash report and I hope you can help me out…..
    Thanks….
    Process: QuickTime Player 7 [2644]
    Path: /Applications/Utilities/QuickTime Player 7.app/Contents/MacOS/QuickTime Player 7
    Identifier: com.apple.quicktimeplayer
    Version: 7.6.6 (7.6.6)
    Build Info: QuickTimePlayer-17090000~1
    Code Type: X86 (Native)
    Parent Process: launchd [128]
    Date/Time: 2012-03-12 16:17:25.704 +0000
    OS Version: Mac OS X 10.6.8 (10K549)
    Report Version: 6
    Interval Since Last Report: 379412 sec
    Crashes Since Last Report: 23
    Per-App Interval Since Last Report: 72239 sec
    Anonymous UUID: 87A45A10-7668-4278-B163-A83B9809C9A5
    Exception Type: EXC_BREAKPOINT (SIGTRAP)
    Exception Codes: 0x0000000000000002, 0x0000000000000000
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Dyld Error Message:
    Symbol not found: _QTValidateAudioChannelLayout
    Referenced from: /Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeCompon ents
    Expected in: /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    Binary Images:
    0x1000 – 0x120fef com.apple.quicktimeplayer 7.6.6 (7.6.6) /Applications/Utilities/QuickTime Player 7.app/Contents/MacOS/QuickTime Player 7
    0x1cac000 – 0x1cb0ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugI n.bundle/Contents/MacOS/AudioIPCPlugIn
    0x1cb5000 – 0x1cbbff7 com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bun dle/Contents/MacOS/AppleHDAHALPlugIn
    0xc800000 – 0xd550feb com.apple.QuickTimeComponents.component 7.7.1 (2315) <1826E4DB-15C2-3495-A278-A17ADEDB0A62> /Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeCompon ents
    0x70000000 – 0x700cbfff com.apple.audio.units.Components 1.6.5 (1.6.5) <412DBD1B-E9B5-E67C-99E4-820BF38239AC> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0x8fe00000 – 0x8fe4163b dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
    0x90003000 – 0x9007dfff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x9007e000 – 0x90084fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels. framework/Versions/A/CommonPanels
    0x90085000 – 0x900b6ff7 libGLImage.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dyl ib
    0x900fb000 – 0x9015cfe7 com.apple.CoreText 151.12 (???) <98F53C15-1D29-A2B3-0717-5A26A2699163> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ CoreText.framework/Versions/A/CoreText
    0x9015d000 – 0x90166ff7 com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x9016e000 – 0x901c6fe7 com.apple.datadetectorscore 2.0 (80.7) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDe tectorsCore
    0x9074f000 – 0x9075bff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
    0x9075c000 – 0x9075dff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/Tru stEvaluationAgent
    0x9075e000 – 0x907a1ff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationSer vices.framework/Versions/A/NavigationServices
    0x9170f000 – 0x9170fff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
    0x9171e000 – 0x917ccff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework /Versions/A/Ink
    0x917cd000 – 0x917d0ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x917d1000 – 0x917e9ff7 com.apple.CFOpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpen Directory.framework/Versions/A/CFOpenDirectory
    0x918b6000 – 0x918bcfe7 com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/C ommerceCore.framework/Versions/A/CommerceCore
    0x918bd000 – 0x918f0ff7 com.apple.AE 496.5 (496.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.fram ework/Versions/A/AE
    0x918f1000 – 0x91a98ff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
    0x91a99000 – 0x91a99ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x91af7000 – 0x91b01ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecogni tion.framework/Versions/A/SpeechRecognition
    0x91b02000 – 0x91c2fffb com.apple.MediaToolbox 0.484.60 (484.60) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbo x
    0x91c30000 – 0x91c9fff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.fr amework/Versions/A/libvMisc.dylib
    0x91ca0000 – 0x91ca4ff7 libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.d ylib
    0x91cac000 – 0x91cf5fe7 libTIFF.dylib ??? (???) <4A3EF156-D4FE-95E2-FA05-7BD76FF27CEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x91d3c000 – 0x91eb7fe7 com.apple.CoreFoundation 6.6.6 (550.44) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x91ecc000 – 0x92237ff7 com.apple.QuartzCore 1.6.3 (227.37) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x92238000 – 0x9237bfef com.apple.QTKit 7.7 (1789) <4D3AA05F-D4D3-0D43-99D7-F26E4640BEE7> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x9239b000 – 0x923dcff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x924d3000 – 0x924d3ff7 com.apple.quartzframework 1.5 (1.5) <4EE8095D-5E47-1EB6-3A8A-6ECE3BEC8647> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x924d4000 – 0x924e1ff7 com.apple.NetFS 3.2.2 (3.2.2) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x92651000 – 0x92661ff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWra ppers
    0x92662000 – 0x92682fe7 libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
    0x9273f000 – 0x9274aff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x9277e000 – 0x92c39ff7 com.apple.VideoToolbox 0.484.60 (484.60) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbo x
    0x92c3a000 – 0x92c44fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.f ramework/Versions/A/CarbonSound
    0x92c45000 – 0x93434557 com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ CoreGraphics.framework/Versions/A/CoreGraphics
    0x9346c000 – 0x93481fff com.apple.ImageCapture 6.1 (6.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture. framework/Versions/A/ImageCapture
    0x934d6000 – 0x9358ffe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
    0x935a9000 – 0x935a9ff7 com.apple.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x935aa000 – 0x935ccfef com.apple.DirectoryService.Framework 3.6 (621.12) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryServi ce
    0x935cd000 – 0x93648fff com.apple.AppleVAFramework 4.10.27 (4.10.27) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x93674000 – 0x93674ff7 com.apple.Cocoa 6.6 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x93675000 – 0x936d2ff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x936d3000 – 0x9371affb com.apple.CoreMediaIOServices 140.0 (1496) /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/Core MediaIOServices
    0x9371b000 – 0x9371bff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Application Services
    0x9371d000 – 0x937affe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ PrintCore.framework/Versions/A/PrintCore
    0x937b0000 – 0x9381eff7 com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.f ramework/Versions/A/QuickLookUI
    0x9382a000 – 0x93864ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <6875335E-0993-0D77-4E80-41763A8477CF> /usr/lib/libcups.2.dylib
    0x93865000 – 0x93966fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) /usr/lib/libxml2.2.dylib
    0x93a1e000 – 0x93a32ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x93a6c000 – 0x93b28fff com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ColorSync.framework/Versions/A/ColorSync
    0x93b29000 – 0x93b66ff7 com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfi guration
    0x93b67000 – 0x93b67ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.fr amework/Versions/A/vecLib
    0x93ba9000 – 0x93bb7ff7 com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x93c2d000 – 0x93e93ff7 com.apple.security 6.1.2 (55002) /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x94198000 – 0x94198ff7 com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x94199000 – 0x943c4ff3 com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzCompose r.framework/Versions/A/QuartzComposer
    0x943c5000 – 0x943c5ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x943c6000 – 0x943cbff7 com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x944f3000 – 0x944f5ff7 libRadiance.dylib ??? (???) <41E5C5F4-A4C6-0416-08D0-422C88088558> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x944f6000 – 0x944feff7 com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayS ervices
    0x944ff000 – 0x9459cfe3 com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchS ervices.framework/Versions/A/LaunchServices
    0x945d2000 – 0x94618ff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
    0x94785000 – 0x94e00ff7 com.apple.CoreAUC 6.11.03 (6.11.03) <42B31B0F-18F9-29D2-A67C-7B81A47F6D67> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x94e01000 – 0x94e05ff7 IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x9500e000 – 0x9505bfeb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordS erver
    0x9505c000 – 0x95078fe3 com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting .framework/Versions/A/OpenScripting
    0x95079000 – 0x9523bfeb com.apple.ImageIO.framework 3.0.5 (3.0.5) <051752C3-8C25-CF4A-9BFB-C7B6D20E58E8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ImageIO.framework/Versions/A/ImageIO
    0x95a76000 – 0x95b0efe7 edu.mit.Kerberos 6.5.11 (6.5.11) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x95b2d000 – 0x95b6bff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x95c02000 – 0x95d3ffe7 com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x95e81000 – 0x95e8ffe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
    0x95e90000 – 0x96101fef com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x961a5000 – 0x961c6fe7 com.apple.opencl 12.3.6 (12.3.6) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x961c7000 – 0x962a1fff com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/Desk topServicesPriv
    0x962a2000 – 0x962e5ff7 libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x962e6000 – 0x96301ff7 libPng.dylib ??? (???) <05445692-8AF7-CAB6-EBF5-1F7B3A906CCB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x96302000 – 0x9640efe7 libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgramma bility.dylib
    0x9640f000 – 0x96488ff7 com.apple.PDFKit 2.5.1 (2.5.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framew ork/Versions/A/PDFKit
    0x96489000 – 0x965b7fe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x966e9000 – 0x96753fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
    0x96754000 – 0x9675fff7 libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x96760000 – 0x96a84fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.fra mework/Versions/A/HIToolbox
    0x96bea000 – 0x96c10ffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Diction aryServices.framework/Versions/A/DictionaryServices
    0x96c11000 – 0x96c38ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters .framework/Versions/A/QuartzFilters
    0x96c88000 – 0x96cc5ff7 com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x96d01000 – 0x96d04ff7 libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClien t.dylib
    0x96d05000 – 0x96e87fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libicucore.A.dylib
    0x96e88000 – 0x96eccff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x96ecd000 – 0x970affff com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.fram ework/Versions/A/ImageKit
    0x970b0000 – 0x970b7ff3 com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framewo rk/Versions/A/Print
    0x9723b000 – 0x97280ff7 com.apple.ImageCaptureCore 1.1 (1.1) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCo re
    0x9728d000 – 0x97345feb libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x97346000 – 0x97411fef com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServi ces.framework/Versions/A/OSServices
    0x97412000 – 0x97514fef com.apple.MeshKitIO 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshK itIO.framework/Versions/A/MeshKitIO
    0x97515000 – 0x97597ffb SecurityFoundation ??? (???) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoun dation
    0x97598000 – 0x97645fe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
    0x9766c000 – 0x9766dff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x9766e000 – 0x97671ffb com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framewor k/Versions/A/Help
    0x97744000 – 0x97763ff7 com.apple.CoreVideo 1.6.2 (45.6) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x97764000 – 0x97766ff7 com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.fr amework/Versions/A/SecurityHI
    0x97767000 – 0x97797ff7 com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
    0x97798000 – 0x979e2fef com.apple.JavaScriptCore 6534.52 (6534.52.7) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x97a31000 – 0x97e47ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.fr amework/Versions/A/libBLAS.dylib
    0x97e48000 – 0x9872bff7 com.apple.AppKit 6.6.8 (1038.36) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x9872c000 – 0x9880cfe7 com.apple.vImage 4.1 (4.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.fr amework/Versions/A/vImage
    0x9880d000 – 0x98831ff7 libJPEG.dylib ??? (???) <7EBC924F-B2EE-68B0-4EA0-F99EF54F0306> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x98832000 – 0x98833ff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPane l
    0x98834000 – 0x9888aff7 com.apple.MeshKitRuntime 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshK itRuntime.framework/Versions/A/MeshKitRuntime
    0x9888b000 – 0x988cffe7 com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadat a.framework/Versions/A/Metadata
    0x988d0000 – 0x98920ff7 com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyCon trols
    0x98921000 – 0x98931ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
    0x98942000 – 0x989eefe7 com.apple.CFNetwork 454.12.4 (454.12.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwo rk.framework/Versions/A/CFNetwork
    0x98a6d000 – 0x98aa8ffb libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x98aa9000 – 0x98aacfe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
    0x98aaf000 – 0x98af1ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.fr amework/Versions/A/libvDSP.dylib
    0x98af2000 – 0x98b56ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering .framework/Versions/A/HTMLRendering
    0x98b57000 – 0x98e51fef com.apple.QuickTime 7.6.6 (1789) <38255AA2-8087-5AE0-CA4B-1DDE611540B1> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x98e52000 – 0x98eacfe7 com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x98ead000 – 0x98ebeff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ LangAnalysis.framework/Versions/A/LangAnalysis
    0x98ebf000 – 0x98fc1fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
    0x990c2000 – 0x993e2ff3 com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonC ore.framework/Versions/A/CarbonCore
    0x993e3000 – 0x9948bffb com.apple.QD 3.36 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ QD.framework/Versions/A/QD
    0x99676000 – 0x9967dff7 com.apple.agl 3.0.12 (AGL-3.0.12) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x9967e000 – 0x99682ff7 libGIF.dylib ??? (???) <3B4E6D0B-89EB-251F-3693-5187254D5BE2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x99683000 – 0x996abff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <315D97C2-4E1F-A95F-A759-4A3FA5639E75> /usr/lib/libxslt.1.dylib
    0x996ac000 – 0x996beff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/Multit ouchSupport
    0x996bf000 – 0x9973ffeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchK it.framework/Versions/A/SearchKit
    0x99740000 – 0x99b75ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.fr amework/Versions/A/libLAPACK.dylib
    0x99b76000 – 0x99c11fe7 com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ATS.framework/Versions/A/ATS
    0x99c12000 – 0x99c45fff libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x9a9af000 – 0x9a9c3fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
    0x9a9c4000 – 0x9aa17ff7 com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ HIServices.framework/Versions/A/HIServices
    0xffff0000 – 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
    Model: MacPro4,1, BootROM MP41.0081.B08, 4 processors, Quad-Core Intel Xeon, 2.66 GHz, 4 GB, SMC 1.39f5
    Graphics: NVIDIA GeForce GT 120, NVIDIA GeForce GT 120, PCIe, 512 MB
    Memory Module: global_name
    Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
    Network Service: Ethernet 2, Ethernet, en1
    PCI Card: NVIDIA GeForce GT 120, sppci_displaycontroller, Slot-1
    PCI Card: ATTO Celerity FC-41ES, sppci_fibrechannel, Slot-2@7,4,0
    PCI Card: pci15bc,105, sppci_fibrechannel, Slot-2@7,4,1
    Serial ATA Device: HL-DT-ST DVD-RW GH41N
    Serial ATA Device: WDC WD1001FALS-41K1B0, 931.51 GB
    Fibre Channel Device: SCSI Target Device @ 0
    Fibre Channel Device: SCSI Target Device @ 1
    USB Device: Vendor-Specific Device, 0x0fd9, 0x0022, 0xfa200000 / 2
    USB Device: Cruzer Blade, 0x0781 (SanDisk Corporation), 0x5567, 0xfd500000 / 2
    USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000 / 2
    USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0x5a110000 / 5
    USB Device: Sentinel SuperPro 6.3.0, 0x04b9 (Rainbow Technologies, Inc.), 0x0300, 0x1d100000 / 2
    USB Device: Hub in Apple Pro Keyboard, 0x05ac (Apple Inc.), 0x1003, 0x3d100000 / 2
    USB Device: Apple Pro Keyboard, 0x05ac (Apple Inc.), 0x020b, 0x3d130000 / 3
    FireWire Device: built-in_hub, Up to 800 Mb/sec
    Ben Mills replied 14 years, 5 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    March 14, 2012 at 1:37 pm
    The crash report doesn’t really help. What might help would be the console logs.
    Meanwhile, what version of OSX? QuickTime is such an integral component, that in your removing stuff you may have screwed that up.
    Quick desperate move: grab the latest combo installer for your version of OSX and run that.
    Best,
    Jeff G
    Certified Master Trainer | Adobe, Apple, Avid
    You should follow me (filmgeek) on twitter. I promise to be nice.
    My book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Lynda.com – Compressor Essentials 3.5 and 4
    Contact me through my Website
  • Ben Mills
    March 14, 2012 at 1:41 pm
    No worries, I have solved the issue now.
    I took a copy of the quicktime.framework, library/quicktime and system/library/quicktime folders from another machine also running 10.6.8 and QT Pro and it worked a treat.
    I was previously trying to replace those folders with ones from 10.7.1 which is why it was causing the crash.
    Thanks for getting back to me though!
